I have searched high and low, and haven't found a single fitting...can you post a pic of where these are? I have found where I would put some, but nothing. Thanks.
It's a blizzard here and COLD.
But they are on each end of the front axle, in the U joint right at the hub. (in the hub).
Thanks, I will look there. Stay warm! Btw nice truck...had an 05 6.0 with a very similiar setup. Ha every time I see your profile pic it takes me back.
Thanks for the compliment!
Here is a bad pic of the U joint. The jerk is inside here.
My last truck was an 2006 6.0 and it had the same (2) grease fittings. At 36,000 miles, I took a grease needle to all of the joints that didn't have a fitting. I traded it on 8/25/11 with 110k miles and everything was still tight.
