1978 - 1996 Big Bronco
1988 Bronco wiring
Old Oct 5, 2011 | 09:21 PM
hartsfive's Avatar
hartsfive
1988 Bronco wiring
I need some help. I have an 88 full size bronco. The motor is a 351 and leaks oil real bad. I have another 351 out of an 1994 F150 and the wiring harnesses don't match up. I need to know where I can come up with a way to mesh the harness to the fire wall harness to make them work together.
Old Oct 5, 2011 | 09:33 PM
Edgethis's Avatar
Edgethis
What transmissions do the 2 motors have?
Old Oct 6, 2011 | 09:00 AM
hartsfive's Avatar
hartsfive
1988 bronco wiring
I am going to use the tranny that is in the 88 and the motor out of the 94
Old Oct 6, 2011 | 11:33 AM
greystreak92's Avatar
greystreak92
Use the 94 harness on the 94 engine... period. You will save yourself a ton of headaches. Assuming the 94 has an automatic, it will be an E4OD. To use the ECM (computer) from the 94 with any other transmission, you just need to put a 400 ohm resistor between the GREEN/RED wire and the LT. BLUE/YELLOW wire in the connector for the MLPS (Manual Lever Position Sensor) that runs to the transmission. Put the resistor in at the connector/pigtail for the MLPS or the resistance will be off.
Old Oct 6, 2011 | 04:49 PM
hartsfive's Avatar
hartsfive
The problem I am running into is that the harness connector for the 94 is rectangle and the spot where the harness is supposed to connect on the firewall is round, hence the wiring harness for the 88 was round also. Any thoughts on how to connect the two?
Old Oct 6, 2011 | 05:24 PM
Edgethis's Avatar
Edgethis
Prolly gonna have to figure out the wires and splice the round connector on.
japarks
Large Truck
13
Jun 14, 2012 08:02 PM
Blueoval_boy_64
Engine Swaps
Dec 16, 2007 11:39 AM
Fanboy
Dec 3, 2007 06:18 PM
radramrod2
Jan 26, 2005 10:33 AM
racerdon
Electrical Systems/Wiring
Dec 19, 2003 05:05 PM
