egr delete, what else while in there
Old Oct 5, 2011 | 02:58 PM
waumpuscat's Avatar
waumpuscat
I think I am going ahead with a egr delete on my 05 with 44,000 miles on it due to deltas. Here is what else will be done:
1) STC fitting, anybody got the part #
2) Stand pipes and dummy plugs
3) Clean turbo and replace boots
4) replace thermostat
5) bluespring kit
6) and oil cooler of coarse
what else can I do since I am that deep and want to get all that is reasonable? is there another part that goes with the standpipe and dummy plugs?
All part #s and suggestions welcome
Old Oct 5, 2011 | 03:10 PM
npccpartsman's Avatar
npccpartsman
Part numbers:
Kit for dummy plugs and stand pipes: 6E7Z-9A332-B
STC Kit 4C3Z-9B246-F 1879930c91 (includes turbo gasket kit)
Fuel pressure regulator kit 3C3Z-9T517-AG 1843065C98 or
6E7Z-9C165-B 1854267c94 (no cover)
Regulator cover gasket: 3C3Z-9C065-AA
Low Pressure Oil
Oil Cooler Kit - Replaceable Core 3C3Z-6A642-CA
Thermostat RT-1169 (motorcraft)
The turbo boots are "engine specific" by year and model. IMHO there is no reason to replace the boots until they wear out. I had 150K on elbow boot when it cracked. The rest are still original at 173K and they've all seen in excess of 35 psi at one time or another.
Old Oct 5, 2011 | 03:18 PM
davidkstyler's Avatar
davidkstyler
Old Oct 5, 2011 | 04:39 PM
waumpuscat's Avatar
waumpuscat
sure appreciate those numbers, have I missed any particular procedure or part that needs to be attended to while in there? I may consider the bulletproof egr cooler and turn it off with the sct, I need to do more research on that. Trying to ensure that I can pull those long hot hills next summer with the 12000lb fiver and hot temperatures.
Old Oct 5, 2011 | 05:03 PM
_Me2_'s Avatar
_Me2_
I think you've got it covered unless you want to go for it all and do the studs/gaskets. I also went with the BP EGR cooler instead of the delete, but the delete is fine. I wouldn't pass the visual inspection with a delete where I live if the tech knows what he's doing, and it wasn't that much more to stick with the BP.
As mentioned, no real need to do the boots if they are still holding fine, and I wouldn't even mess with the thermostat unless you're not getting up to temp right now.
Old Oct 5, 2011 | 06:28 PM
waumpuscat's Avatar
waumpuscat
Me2, did u do the sct programmer to turn off the egr valve? Is that really the same as a delete? I am thinking of going in that direction for the flexibility and ensuring that I do not get a check engine light. If I were do the delete only, would I be able to ensure that I could turn off that check engine light without using a programmer?
Old Oct 5, 2011 | 06:41 PM
_Me2_'s Avatar
_Me2_
I did turn the valve off with the tune. As I understand it, if you do a delete without a tune, you will get a CEL unless you leave the EGR valve plugged in. If you leave it plugged in, I believe it will throw a code for low/no flow, but I don't think that code will trigger a light. I'm sure somebody will correct me if I'm mistaken about that.
Old Oct 5, 2011 | 07:19 PM
davidkstyler
I have also heard that the engine cooling fan may not operate correctly with the ERG valve unplugged.
The most important thing to do, if you have a high delta T, is to flush the cooling system and replace the engine oil cooler before your EGR cooler fails because of the high temperatures.
madhatt
Mar 19, 2014 10:10 PM
Lowe
Jul 5, 2012 02:50 PM
airjeff
Oct 9, 2011 08:17 AM
MD250
Mar 16, 2011 06:17 PM
FireBaller74
Dec 15, 2010 06:15 AM
