Harmonic Balancer
Old Oct 5, 2011 | 10:00 AM
Davidwent's Avatar
Davidwent
Harmonic Balancer
Maybe I haven't looked hard enough, but I haven't seen to much mentioned if people are going new with this when re-building. I know it's important, and with so many things I'm not sure what to look for to see if it's bad.
For those of you who do not know I didn't hear this motor run before I bought it
TIA
David
Old Oct 5, 2011 | 11:10 AM
1986F150six's Avatar
1986F150six
Look for any pieces of loose rubber [front and back]. On a running engine, one can take a crayon or chalk and make a line across the balancer, from side to side. After driving, look at the line to see if it has shifted? If so, the bond between the metal ring and rubber is failing.
Old Oct 5, 2011 | 11:38 AM
Davidwent's Avatar
Davidwent
Thank you sir!
David
Old Oct 6, 2011 | 01:17 AM
F-250 restorer's Avatar
F-250 restorer
I have a 75 that I pulled from the j/y and rebuilt. I used the harmonic balancer that was on it. Surprisingly, when I looked for my year engine I was surprised to see at A.zone that a new one costs $400!! But other years, early 80's for example, cost but $80! I would say that if it looks good, and then your timing sets fine, I would keep what you have. If you get probs, it is a simple matter to replace.
I also see that Comp Cams makes a trick one for over $400.
Old Oct 6, 2011 | 02:48 PM
Davidwent's Avatar
Davidwent
Thanks for the info! Mine is a 78 and once I got all the gunk off of it, it looks really good. As you suggested I will re-use it and as long at it times fine I'm good
Thanks again
David
crazer42
Dec 15, 2010 04:59 PM
three on the tree
Jun 12, 2010 08:17 PM
73Galaxie
Jun 17, 2005 01:15 AM
tastyklair
21
Aug 8, 2004 03:46 PM
Berlinetta00
Jun 13, 2003 08:44 PM
