Rearend problems, need help!
Old Oct 5, 2011 | 11:50 PM
Iallwork's Avatar
Iallwork
opened up the cover. Everything looks fine. no metal shavings. besides what ya might see in a diff with 260,000. the pass side has the leak and I think it has a bearing that is bad. The brakes look like new ( besides being covered with oil). There are metal chunks all over the brakes, so it might be the wheel bearing. I need a spndle nut before I can take it apart. I will try to get one tomorrow.
It's not a LS diff as far as I can tell. I can see the little gears on the ends of the axle shafts. No clutch packs. just open. Should I post my VIN?
Old Oct 5, 2011 | 11:52 PM
brokeisnojoke's Avatar
brokeisnojoke
Mine was an ls I now have a posi unit and hate it!
Old Oct 6, 2011 | 12:25 AM
madpogue's Avatar
madpogue
Weird; the L before the 10 shoulda meant limited slip. At this point, I'd do two things - put a paint mark on the driveshaft, turn a wheel/drum one turn and see how many turns the driveshaft turns (that'll tell you the ratio), and open the door and look at the axle code on the door sticker. C5, D5, F5 would be 4.10 limited slip, and 35, 45, 65 would be 4.10 unlimited (?) slip. If it ends in a 9, it's a 3.55.
Old Oct 6, 2011 | 01:41 AM
Iallwork's Avatar
Iallwork
the pinion gear says 410 on it. I am going to look at the door sticker now.
Old Oct 6, 2011 | 01:58 AM
Iallwork's Avatar
Iallwork
VIN 1fthf36f5vea......
Axle code C5
Is that enough?
Old Oct 6, 2011 | 02:02 AM
Iallwork's Avatar
Iallwork
Why do you hate it?
Old Oct 6, 2011 | 02:48 AM
madpogue's Avatar
madpogue
Axle code C5
Is that enough?
C5 is 4.10 LS, 8500 lb (?) GVWR. So unless it's been gutted, it's a limited-slip. Consistent with the behavior.
Old Oct 6, 2011 | 07:48 PM
Iallwork's Avatar
Iallwork
Is this a limited slip?
Old Oct 6, 2011 | 09:04 PM
Iallwork's Avatar
Iallwork
So all the bearings looked good. I replace the seals and brakes and fluid. Now just wait to see if it gets worse, but seems better for now thanks again for the help and advice. I still don't think it is a limited slip. When its jacked up, in park, and I spin one wheel the other spins the opposite direction.
Old Oct 6, 2011 | 09:33 PM
brokeisnojoke
It's going to with no weight on it. Turn sharp in stones or new asphalt. And if its posi you will see why I hate mine lol. Or go burn the tires off that will tell you if its posi or not lol
Old Oct 6, 2011 | 09:54 PM
Iallwork's Avatar
Iallwork
I put an Auburn in my suburban when the 10 bolt went to pieces (and I mean pieces), and I really liked it. It was kinda noisy when I took a sharp turn on pavement.
Old Oct 6, 2011 | 10:01 PM
brokeisnojoke
Ya that's why I don't like it that much. But it will be there until I trash it lol
Old Oct 6, 2011 | 10:09 PM
  #28
Iallwork's Avatar
Iallwork
Where I live a posi is really nice to have for winter driving. I don't mind a little mechanical noise if I know it's not hurting any thing. But ya the clunk clunk clunk caused a little worry right after I finished it and had to travel on a camping trip pulling a boat and a car full of kids. But it held out for years. I sold it and it's probably still good.
Old Oct 7, 2011 | 05:11 AM
  #29
brokeisnojoke
Mine never clunked. On new or smooth asphalt the inside tire spins and same with in stones. Its not completely horrible but it's something to think about. Im building mine into a pulling truck so soon (wen its running lol) it will be worth it
Amicus
Aug 24, 2016 10:50 PM
preppypyro
Jun 30, 2011 06:25 PM
haybayian
Aerostar
Jun 9, 2008 01:55 AM
why165
Jul 5, 2005 10:24 PM
ohio bob
Feb 11, 2001 06:21 AM
