Problems AGAIN!!!
Old Oct 5, 2011 | 08:23 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Hey Darrel have you got a oil pressure gauge you could hook up to see what your lpo pressure is.
Old Oct 5, 2011 | 08:27 PM
nissandoc's Avatar
nissandoc
Have some stuff at work I can probably make work. Do you know what the specs are and the best place to hook up the gauge?
Old Oct 5, 2011 | 08:31 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by nissandoc
Tonight after letting truck run for about 20 minutes it cut off and wouldnt start back up.
I put in the gray CPS that I had for my spare and still no start.
ICP would only build to about 150. Unplugged sensor and still no start. I'm thinking that I have either a weak LPOP that cant keep up or a bad IPR solenoid.
Thoughts?
Or bad IPR that's stuck open.
What's the oil level in the res now.
Did you monitor EOP with AE while cranking? Even a low reading would mean the HPOP res is filling up enough. The EOP sensor is on top of the
reservoir. If there were allot of air in the res you probably wouldn't get any reading.
Old Oct 5, 2011 | 08:35 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Not right off hand but let me see what I can find. But 60 psi sticks in my head.
Old Oct 5, 2011 | 08:41 PM
PaysonPSD's Avatar
PaysonPSD
I just added the specs to my previous post.
10 PSI at idle but while cranking it would be less.
Old Oct 5, 2011 | 08:46 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Thanks Robin
Old Oct 5, 2011 | 08:50 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Robin
My pleasure Richard.
It's a jpg. Save it on your computer.
Old Oct 5, 2011 | 08:51 PM
Bigcat350's Avatar
Bigcat350
Thoughts?
Darrell
Have you ever took a IPR apart and cleaned it? Its pretty easy I have seen one that quit working that had a very small piece of crud in the little hole inside. I have a used spare IPR that I could send you if you would like to try it.
Old Oct 5, 2011 | 09:30 PM
nissandoc's Avatar
nissandoc
Thanks Robin. Wanted to check the level in the reservoir but didnt bring any tools home with me.
Eddie, I took it apart and cleaned it last summer before RRE.
What seems funny to me is that it will run just fine for 10-2o minutes at idle and then just dies like I cut the key off. No spit or sputter. Its done this 2 days in a row.
Also when it was running the engine coolant temp was reading almost 300* on AE and it had only been running for about 5 minutes so I know it wasnt that hot. Wiggled the wires at the connector but it didnt change. I did get a screen shot but cant figure out how to post it.
Old Oct 5, 2011 | 09:43 PM
mueckster's Avatar
mueckster
AE will read screwy on ECT on an auto trans truck. It can read pretty close after full operating temp, but is way off 'til then.
Have you tried ohming the IPR coil? It should read between 5 and 20 ohms. Just a WAG, but it could have an "open" in it when it heats up.
Old Oct 5, 2011 | 09:44 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Change it to a JPG or a PDF.
Old Oct 5, 2011 | 09:46 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Have you checked the big bundle of wiring where it goes over the valve cover to see if one of the wires may be rubbed thru and is shorting?
Old Oct 5, 2011 | 09:48 PM
  #28
PaysonPSD's Avatar
PaysonPSD
Where's the stock idiot gauge when AE reads 300? It would be nice to compare AE EOT to ECT while the ECT is rising to that high a temp. If the EOT isn't showing close to the same temp I woud think the ECT sender is bad.
No one likes to throw parts at a problem but coolant temp senders are cheap.
Old Oct 5, 2011 | 09:49 PM
  #29
nissandoc's Avatar
nissandoc
If doing that was as easy as rebuilding a transmission I would have already done it. LOL. I dont know chit about how to do stuff on computers.
Old Oct 5, 2011 | 09:53 PM
  #30
nissandoc's Avatar
nissandoc
EOT was at 125 when ECT was at 302.
Gauge was at about 1/8th.
