Sponsored by: Real Truck
Help with steering wheel, steering box alignment
Old Oct 4, 2011 | 01:34 AM
luny1's Avatar
luny1
I also posted in the 99 to 03 forum.
Two problems.
1)How do I center a steering box that was installed in the wrong position. The wheels were turned,and so was the position of the Pittman arm.
2)My "helper" unhooked the seat belt I had on the steering wheel,and doesn't remember how many times he turned it.
What do I need to do to get everything aligned,and centered.
Old Oct 4, 2011 | 03:10 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
2 ways to find the center of the steering range. note, I don't know if this style of steering box has an internal stop or not. The box could very well just spin forever. if this is the case STOP!.
center the wheels, get a puller and remove the pitman from the steering box
with the pitman removed, turn the wheel completely all the way until it stops. then go the other way and count the number of turns. do this twice to verify you have the correct number of steering wheel turns. then spin the wheel 1/2 that distance.
make sure the steering wheel is straight and lined up. at this point, put the pitman back on the steering box. make sure the tires are straight, and the steering wheel is straight.
Remove the airbag and look at the clockspring. remove the pitman as described above
using the clockspring as a reference, center the wheel. you are looking for the same amount of slack when turning left and right.
make sure the wheel is straigth up/down, then install pitman and put airbag back on
Old Oct 4, 2011 | 08:58 AM
luny1's Avatar
luny1
The lift I have makes it impossible to remove the Pittman arm without removing the box.
I'll do some research and find out how to remove the airbag.
Thank you!
tabijan
Jun 13, 2014 03:10 AM
hooler1
Jun 25, 2012 01:43 AM
luny1
Oct 4, 2011 05:12 PM
vinmanin
May 5, 2010 05:27 AM
13MWZ
Nov 24, 2007 05:38 PM
