Another dumb question.
Old Oct 3, 2011 | 11:51 PM
MikeSteward's Avatar
MikeSteward
8th Gear
I'm sure this is as amateur as it gets, but I don't know - so I'm asking...
I'm going to be replacing the intake manifold on my 85 F250 (460) in the next day or two. In order to do so, I need to pull the distributor. I've never done it before, but I know that I need to do so carefully.
So my question is.... since I'm only pulling it temporarily, and reinstalling the same unit, is it necessary for me to find TDC? Or will I be okay as long as I make marks on the outside of the housing (which will line up with marks I make somewhere on the block/engine) as well as marking the inside of the housing where the rotor is pointing (prior to removal)?
Thanks in advance.
Old Oct 4, 2011 | 08:13 AM
Stangrcr1's Avatar
Stangrcr1
While it is not required, so long as it goes back in the same as it came out, it is better to find TDC just in case you can't remember EXACTLY how it came out.
And TDC is not that hard to find. A few minutes spent to find TDC will save lots of headache later if you put it back in wrong.
Old Oct 4, 2011 | 08:50 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Actually, if you have help, you can get the intake off without pulling the distributor, bot it can be a pain on a truck. I've done it.
mavrik4x4
Nov 10, 2011 08:18 PM
CanadianBigBlue460
Oct 27, 2011 04:54 AM
rcav8or
Flathead V8 & Flathead 6
Jul 24, 2008 12:43 AM
sb1234_99
1978 - 1996 Big Bronco
34
Aug 16, 2007 05:41 PM
Mav06
Feb 7, 2007 12:03 AM
