1978 - 1996 Big Bronco
stuck distributor cap on a 460
Old Jul 9, 2007 | 07:38 PM
sb1234_99's Avatar
sb1234_99
I'm tring to pull the intake off my 460 and one of the tops of the bolts broke off. The intake will still come off but I need to pull the distributor off for clearence but I can't seem to get it off. This may be a stupid question but how do I get it off. I've never actually pulled one off. I took what I thought to be the only bolt out of the side but it will not budge. Do I just have to persuade it off or is there more to it? Thanks for every ones help I really appreciate it.
Old Jul 10, 2007 | 09:22 AM
ranger429's Avatar
ranger429
Distributor or distributor cap is stuck? Sounds more like you can't get the dizzy out of the block? Common problem when aluminum meets cast iron, corrosion sets in. It will take some persuading to get it out, might want to soak the base of it with PB Blaster for a day or 2 first.
Old Jul 10, 2007 | 06:42 PM
sb1234_99's Avatar
sb1234_99
yes you are correct, its the whole distributor that is stuck. After pulling the one bolt on the side should the whole thing just pull out or is it threaded in?
Old Jul 10, 2007 | 07:31 PM
ranger429's Avatar
ranger429
That is the corrosion I was reffering to. It is not threaded in.
Here is a pic of a 400 that required some persuasion to get out. I eventually beat it out from the bottom side.
Old Jul 10, 2007 | 07:43 PM
sb1234_99's Avatar
sb1234_99
I'm trying to leave the motor in the truck but so I hope it doesn't come down to that but I have to get the intake off to figure out why I found 2 bent push rods.
Old Jul 10, 2007 | 08:17 PM
ranger429's Avatar
ranger429
I'd suspect bad timing chain and gears. Put a socket on the crank bolt and turn it back and forth watching the dizzy rotor to see how long it takes to turn. If it takes to long that is a lot of play in the chain or bad cam gear. Ford originally used a phenolic(hard plastic) cam gear and they would wear away to just about nothing.
Old Jul 10, 2007 | 08:49 PM
sb1234_99's Avatar
sb1234_99
After some more persuasion I finally got the distributer off & the intake. After I took the intake off I found a metal "pan" covering the valves & entire block in between the heads. I don't see the "pan" in the pic that you posted above? What is it and how do I get it off?? Do I have to pull the heads and exhaust? Someone told me that I need to check the valves for movement. Please don't laugh too much I have no idea/guidence on what I am doing! Thanks
Old Jul 10, 2007 | 09:50 PM
ranger429's Avatar
ranger429
The pan is called a valley pan or intake gasket. It lifts straight off with no tools needed. Do a compression test and record your #'s so you know before pulling the heads.
Old Jul 11, 2007 | 05:58 PM
sb1234_99's Avatar
sb1234_99
well I didn't check the compression or pull the heads yet but I got the pan off and was finally abe to put a new push rod in and turn the motor. when the cam pushes the rod up into the rocker it breaks the rocker and the spring does not move. On the other side where I pulled out the bent push rod everything seems to be moving ok. What should my next step be?
Old Jul 11, 2007 | 06:24 PM
ranger429's Avatar
ranger429
Do a compression test, sounds like bent valve.
Old Jul 11, 2007 | 09:53 PM
sb1234_99's Avatar
sb1234_99
This may sound stupid, but how do I do a compression test?
Old Jul 12, 2007 | 07:44 AM
ranger429's Avatar
ranger429
LOL, there must be no one else reading this forum.
Go to the parts store and ask them for a compression gauge, they make 2 modells. One kind has a tapered rubber tip that fits in the spark plug hole and you hold it there while turning over the motor and the other has screw in connectors to go in the plug hole. Record the reading on the gauge, you want all of the cylinders to be pretty close to the same number.
Old Jul 15, 2007 | 12:45 PM
sb1234_99's Avatar
sb1234_99
ok I finally got a compression tester now I just need to recharge the battery in the truck. I also found a bent valve in the head where the bent push rod was. Why would that have bent. I found a newly rebuilt set of heads a my a friend of a friends house. He only wants 250 for the set so I think I am going to buy them but should I feel alright about not having to do any other work or is the problem still somewhere else that caused the bent push rods? I'll post the compression results in a couple hours after the battery is ready.
Old Jul 15, 2007 | 08:42 PM
sb1234_99's Avatar
sb1234_99
compression test complete. I don't know what the actuall numbers of the cylinders are but on the driver side starting at the radiator I had 90, 100, 45, 120. On the passenger side starting at the front 10,100,110,120. The two low ones are the cylinders that had the bent push rods. After watching the motor turn over I have figured out that each one of the valves are sticking down on these particular spots. So if I buy the new heads does it sound like my problems will be over? what makes the valves stick? The truck did suposedly sit for 2-3 years .
Old Jul 15, 2007 | 09:10 PM
ranger429's Avatar
ranger429
Worn out valve guides. Take the heads in to a machine shop for an estimate to fix before buying those other heads UNLESS they have been checked and had a valve job done. Those #'s sound terrible.
Usually a valve job is around a 100 bucks.
