Sponsored by: Real Truck
power steering problem
Old Oct 3, 2011 | 08:37 PM
SuperDutyScaler's Avatar
SuperDutyScaler
my 2004 SD is starting to act up, its been in the mid 40's here for the past week and a half no and i can hear my power steering pump wining. And when i try to pull into a parking spot or back my trailer up the truck wont even turn. Ive read the post about flushing the fluid for a diesel but i have a 5.4, is it the same or different because i dont have hydro boost?
Old Oct 3, 2011 | 09:23 PM
Bigpipes 35's Avatar
Bigpipes 35
Hey Scaler on mine i just pulled the line off the cooler and drained it into a bucket that got 99 percent of the old fluid out. Then I refilled with synthetic atf. Hopefully that will help.
Old Oct 4, 2011 | 06:45 PM
SuperDutyScaler
ive read where guys jack the front up and turn the wheel back on forth to push some out too?
Ill try this tomorrow, did you remove your front bumper first or did you add a piece of hose so it didnt get all over
Old Oct 4, 2011 | 07:10 PM
Bigpipes 35
No I didnt remove the bumper once you pull that line off the cooler it drains the cooler . the resivoir and the pump. And best of all doesnt make a mess. Just make sure you have a bucket under it..
Old Oct 4, 2011 | 07:26 PM
SuperDutyScaler
what hose the top one on the cooler or the bottom one on the cooler? and when you remove it doesnt the fluid run out of the cooler and the other line all over the place?
Old Oct 4, 2011 | 08:37 PM
Bigpipes 35
I think I did the bottom one that way it drains the cooler too. The fluid is not under presure as long as you dont start the truck. Just put a bucket under it , it will only be a couple quarts.
Old Oct 4, 2011 | 08:50 PM
SuperDutyScaler
sweet! thanks alot tomorrow ill be doing this and im hopeing it fixes the whine ive been getting lately
Old Oct 5, 2011 | 08:09 AM
BareBones's Avatar
BareBones
I've never previously had this happen on a vehicle, but about a year ago I had a power steering whine that I tracked down to a loose and leaking nut on the brake lines. Just tightened it up and added fluid.
I'd throw a piece of clean cardboard under the driver's side firewall overnight and check for leaks.
Old Oct 5, 2011 | 06:52 PM
Bigpipes 35
Good luck and let me know how it goes.
Old Oct 5, 2011 | 09:14 PM
SuperDutyScaler
i didnt get a chance today, i had to work late but im shooting for tomorrow
abe
May 22, 2015 01:03 PM
stephendacosta
Mar 14, 2015 02:34 PM
Fordzilla80
36
Dec 11, 2011 07:18 AM
thordehr
May 30, 2010 04:17 AM
warmdye
Aug 5, 2002 05:12 PM
