1978 - 1996 Big Bronco
brake rotor
Old Mar 4, 2014 | 09:14 PM
mudslinging79's Avatar
mudslinging79
brake rotor
ok, i have a 1993 eddie bauer edition ford bronco, looking at replacing the front rotor. book says there are 2 setups, one is the hub doesnt have to come off, the other the hub has to come off... is there a way to tell which one i have before tearing into it?
Old Mar 4, 2014 | 10:38 PM
FourXFord2's Avatar
FourXFord2
Every front rotor I've replaced required removal of the hub. Mostly so the wheel studs can be pressed out to free the hub from the rotor. I think the Rangers, bronco II's and Explorers had a design which the wheels held the rotors instead of the studs. Might be a 2wd thing too.
Old Mar 4, 2014 | 11:08 PM
mudslinging79
crap. the b-2 i had had to have ths hubs n bearings off to replace the calipers also.
Old Mar 5, 2014 | 04:59 PM
NewEnglander's Avatar
NewEnglander
Yeah you have to take the whole guts out of the hub and it will split into 2. It's a fairly simple job just required some muscle when you put the 2 back together. While your in there it won't be a bad idea to do bearings and hub seal. Also a fairly simple job.
Old Mar 5, 2014 | 09:36 PM
mudslinging79
screw it, made an appointment for it at the shop. too wet to be dicking around with it
94GreenTruck
Aug 12, 2014 07:58 PM
zzyzxroad
2004 - 2008 F150
Oct 20, 2012 11:48 AM
bmxstreet15
13
Feb 16, 2009 02:51 PM
threefiftyone
Aug 30, 2004 05:27 PM
DJack
Jan 11, 2004 07:57 PM
