Hard Steering??
Old Oct 2, 2011 | 04:35 PM
mortmort's Avatar
mortmort
Question Hard Steering??
I have a 2006 Lariat 5.4 Super Crew 4X4 and the steering on truck is very hard to turn and does not return to centre without manually doing it. Has anyone experienced this issue or have any recommendations or can solve my problem???
Thanks
*****Thank you for the replies and help. Sprayed u-joints with oil and all is good. ****
Old Oct 2, 2011 | 05:07 PM
Brandon bolak's Avatar
Brandon bolak
the best i can say is check your power steering fluid if its not that it could be the pump itself.... if its not either i have know clue.
Old Oct 2, 2011 | 05:08 PM
DPorter's Avatar
DPorter
check front axle u-joints
Old Oct 2, 2011 | 06:02 PM
Ford Agian's Avatar
Ford Agian
I too have encountered the same thing I thappened the day i purchased my truck and the dealer said he chaged a bushing in the steering colum thats what I knowhope it helps.
Btw 2008 f150 5.4 scab
John
Old Oct 5, 2011 | 07:56 PM
Crager's Avatar
Crager
Had the same problem on my 04 Screw there are two u joints on the shaft that runs from the steering column to the rack hit them with some penetrating oil and see if that helps worked on mine
Blizzard600
2004 - 2008 F150
19
Nov 13, 2018 01:40 PM
79 F-150 Stone
Modular V8 (4.6L, 5.4L)
Nov 21, 2013 05:35 AM
landdesigns
2004 - 2008 F150
Jul 24, 2010 04:22 PM
PSUJTF76
2004 - 2008 F150
Aug 14, 2009 01:07 PM
390Highboy
Jul 22, 2007 08:28 PM
