2008 5.4 Triton, power steering problem
I am driving a 2008 Lariat with the 5.4 Triton motor and 3.73 rear end to see if I want to buy it. Everything seems great except for a power steering issue which I can't find any discussion about.
The steering is hard and choppy when parking and maneuvering and the wheel will not come back to center without considerable force when making a sharp turn.
A little history:
This truck has sat mainly undriven since May and I drove it from Mass to Ohio yesterday. I noticed the steering issue when I first got in it and it never went away.
The fluid is at the correct level and the belt is tensioned.
A little history:
The truck belongs to my best friend who had a brain injury and can't drive. He obviously doesn't remember his old code.
07 f150 steering
My truck was acting the same with regard to your steering problems. I posted the problem on here and someone suggested I oil the steering knuckles as there are 2. I squirted some waste oil on them and haven't had a problem since, that was just over a year ago, hope this helps. I thought it was my rack and pinion first as this was the opinion of a Canadian Tire Mech
Had the same problem w/ my '04. Being cheap, thought I would try to rectify before spending the bux on a new intermediate shaft. My method worked like a charm. Tried squirting with WD40 and other penetrants, to only have problem return after a short while.
Removed shaft from truck and loostened up bearings w/ WD40. Then used a grease gun with one of those needle adapters and pumped silicone grease in, under the little rubber boots, filling the bearings while I worked them all around. That was 2 1/2 years ago and haven't had a problem with them since.
78C_F150_Fevr
01-28-2006 10:48 AM
