Check engine light
Old Oct 2, 2011 | 02:39 PM
triple-b's Avatar
triple-b
Check engine light
2001 exploer sport, need to reset and clear check engine light I know the problem a small pinhole in exhaust that opens up and i fill it in How do i reset check engine light vs paying $20
Old Oct 2, 2011 | 03:57 PM
aquanaut20's Avatar
aquanaut20
Since you did not reveal the offending code, it indicates you do not have access to a scanner nor a code reader....
If you have made the correct repair the CEL will extinguish after a set number of drive cycles.
Pulling the negative battery cable will reset the PCM to factory defaults, CEL OFF, drive monitors OFF.... Philip
kennybrown
Nov 7, 2012 06:40 PM
zoti
1983 - 2012 Ranger & B-Series
26
Feb 28, 2006 06:40 PM
alopez2
Nov 29, 2004 06:54 PM
esiemer
1997 - 2003 F150
Apr 2, 2004 08:24 PM
bkc1964
1978 - 1996 Big Bronco
Dec 31, 2003 01:57 PM
