<HR style="BACKGROUND-COLOR: #ffffff; COLOR: #ffffff" SIZE=1><!-- / icon and title --><!-- message --><!-- google_ad_section_start -->Can any one tell me the size of the fuel line disconnect tool I will need on my 02' Blackwood, (same 5.4 engine as the Navigator)? Just realized I should do the fuel filter change, even though I only have 23,... miles. I have to assume that the previous owner didn't change it either. Looked at my workshop manual & it's located just under the driver's side door, but doesn't give the removal tool size for the gas filter line. Anybody have any firsthand knowledge of this procedure they would like to pass on to all of us other folks that have not attempted this chore, & how often they change their filter?<!-- google_ad_section_end -->
<!-- / message -->
Can't remember the size. I have a tool set with 4 or 5 different sizes. I do remember screwing with it for about an hour. I thought I had the tool lined up right, but the lines wouldn't budge. I kept repositioning the tool and myself under my truck - 98 Expe EB. Finally when the lines seperated, i just happened to be laying right under it and got a face full of fuel. Sorry I can't be more helpful. I'm sure someone else will chime in with more experience than me. But I can tell you to be very careful.
You should buy the set of quick disconnect tools from your local parts store. The set consists of several round insert type tools that release the internal clamp on the fuel line. There are other tools available for this but, I have found this tool set to be the most easy to use. The ones that look like a sissor with rings on the ends are about as useful as a Gelding on a stud farm in my opinion. Some people like them but, I don't.
The set will run about $10.00 or $15.00.
It's a 5/16" unit. I like the plastic one that easily wraps around the line. Insert the removal tool end into the filter and push until it kind of "snaps." Sometimes it's a little resistant and needs several attempts to release. To Icefans point, be careful as when it does release, so does the fuel. Do the other side the same ways. Be sure to release the safety locks first by just pulling down out of the way. Snap the new filter ends back on, making sure of the proper flow direction arrow, pull up the saftey straps, and click the filter back into the holder bracket. Pretty simple.
It's a 5/16, but I just went out and naught the small kit with different sizes. It's just good to have. Once under there place / clip the tool to the line and slide it towards the fuel filter where the line and filter meet and it will unclip. If it has never been done it may require a tiny bit more muscle, but should still be pretty easy. I recommend opening the fuel cap to relieve any pressure and also have a small container because some fuel WILL leak out. Also have the new filter handy and within reach to reduce the amount of spilled gas. Good luck.
Thanks for all the help guys. I changed out the fuel filter using the disconnect tool, with no problems other than a litle gasoline spilling on me!
The gas coming out of the filter was just a little dirty!
At the time when I did mine, I use a friend of the family's set, older, metal set, but worked after playing with the position a little bit. I swallowed a little bit of fuel myself, but it was worth it afterwards!
Agreed, I did the same thing, bought a set from autozone, although my price wasn't that high, as I get first responders discount!
Originally Posted by Oldtrucknut7077
I got my fuel line disconnect tool set at Autozone for around $6-7. The part number I have is #25043.
I am suprised you got it that cheap! Mine ran me like $8.50 after my discount at Autozone.
Glad you got it changed man, The disconnect tool is worth the price, and will pay for itself over a few uses. Hopefully you didn't end up swallowing a little bit of fuel like myself.
LeeLeadingham: Quote:
No, I didn't get any gas near my head, just my hands & arm. Made a trip into the house to immediately wash it off, as I know from safety classes at work that it,(toxic chemicals), can soak into your bloodstream through your fingertip cuticles. <!-- / message -->
I strongly agree with what you are saying. I've already done tons of damage by that, so much, to where it don't bother me anymore. I never wash toxic's off me, i usually wait til i take a break or something lol
I'ts never too late to start purgeing your body of toxic chemicals. The human body can neutralize, or purge, if you stop the adsorpsion of chemicals to your bloodstream, almost all chemicals over time, except "EPOXIE'S"; they stay in your body forever. "LEAD" might be another substance to be concerned about. I worked in the painting industry all my life before I retired, so I was exposed to chemicals on a daily basis. You would'nt believe the national death rate of my profession at such a young age compared to other professions , we die way too early! You women on this board might also give some serious thought to the chemicals you are absorbing into your bloodstream thru your fingertip cuticles when you paint, then wipe off your fingernail polish.
