Remote Start Installed, no start.
Old Oct 2, 2011 | 06:52 AM
SNIPER168308's Avatar
SNIPER168308
2005 Excursion 6.0 PSD w/ PATS anti-theft system.. I've posted this on other FTE Forums, so I'm taking the chance someone on one of the others will see this and have the answer.
Ok fellas, I'm about to start throwing tools, (not really, but I feel like it)..... Installed a Presitgue Remote Start (took out of wife's Blazer)..... Got in installed, and will remote start with key in proximity. Learned that I needed a PATS bypass.. Purchased a XPresskt model-PKFM.. Wired in as install said... now I can't get the (*&(^( thing to start.. engine just turns over until battery is drain or I shut down the remote start.
The only two things I can come up with is the negative input to the PKFM bypass isn't getting the negative amperage it needs to communicate or it's not programming to the keys. (followed key program instructions)( step 3 says to immediately start the veh w/ remote start, however it has the delay for the glow plugs to fire, not sure if it's taking too much time until start to finalize programming)(and the damn install directions don't say how many neg amps it takes to effectively communicate)
Not sure what to do next, really getting bent about the situation..
Per4mance
Jan 28, 2018 06:57 PM
Kafn8td
Feb 14, 2014 03:25 PM
SNIPER168308
General Diesel Discussion
Dec 6, 2011 12:23 PM
SNIPER168308
Oct 1, 2011 06:37 PM
Seasprite
2004 - 2008 F150
Oct 18, 2007 09:32 PM
