flashing headlights
Old Oct 2, 2011 | 04:22 AM
75styleside's Avatar
75styleside
flashing headlights
so i was driving my truck and about after an hour my headlights started flashing on and off. all my other lights stayed on, its intermitent and only lasts for a min or so my battery is good my alt is good did a wiggle test on all the wires under the dash and behind the headlights while sitting on the side of the road at night. just thought i would see if anyone else has seen or had this problem?
Old Oct 2, 2011 | 06:12 AM
jim collins's Avatar
jim collins
Bad ground someplace maybe ,that's the most common problem with lighting. ..JIM
Old Oct 2, 2011 | 06:20 AM
moparmusclecars's Avatar
moparmusclecars
I agree, you most likely have a bad ground.
Old Oct 2, 2011 | 07:48 AM
mikeo0o0o0's Avatar
mikeo0o0o0
It could also be the switch itself or an intermittent short.
Headlight switches have a circuit breaker built into them. When it trips it resets automatically in a few seconds.
My guess would be either an intermittent short is causing it to trip then reset or the switch itself is bad. When they go bad, switches can get hot causing the breaker to trip and reset.
Old Oct 2, 2011 | 08:39 AM
dlburch's Avatar
dlburch
in addition to the above suggestions, the dimmer switch could also be going bad.
Old Oct 2, 2011 | 08:47 AM
HIO Silver's Avatar
HIO Silver
2x with Mike... the headlights' current runs through the switch. As electrical systems age, they tend to draw more current which leads to more heat. One way to solve the problem is to unload the light switch and install dedicated relays for the headlights. Generally, you'll end up with brighter lights too.
Old Oct 2, 2011 | 10:56 AM
ctubutis's Avatar
ctubutis
I would also be suspecting one of the switches - headlight switch, dimmer switch.
The factory headlight wiring systems are famous for a tan/white wire melting at the dash switch.
Lots of guys in 80-86 have either made or purchased from LMC a wiring harness that uses the dash switch to actuate relays which then go supply power to the headlights. This keeps all that current out of the cab wiring, and people claim they get brighter headlights.
The online version of LMC's 73-79 catalog seems to kinda suck, things aren't listed where the text says they are but here are two pages of that catalog with the harness I described (Item #47-3660):
LMC Truck Parts - Page 149
LMC Truck Parts - Page 70
Old Oct 2, 2011 | 11:05 AM
tbear853's Avatar
tbear853
My '77 did that a long long time ago, I replaced the relay itself and that stopped it.
Old Oct 2, 2011 | 01:20 PM
75styleside
thanks for all the info guys ill be looking into all of this.
mustangpt
Apr 22, 2015 09:59 PM
NickOlsen53
25
Jan 14, 2014 08:32 PM
Honkey Lips70
Mar 17, 2013 11:33 AM
russ88b2
Bronco II
Mar 12, 2004 06:34 PM
TonyG
Electrical Systems/Wiring
Jun 5, 2002 12:36 AM
