wheel loose
Old Oct 2, 2011 | 01:51 AM
m@m's Avatar
m@m
Question wheel loose
04 f150 4x4 5.4 102000 miles just changed lft frt caliber with bracket,
replaced wheel after tighting lug nuts @ 150lbs noticed that the wheel
slightly would move back and forth when grabing the tire by hand in all directions.there is some wear on each lug nut tread worn ?? can hear a slight metal sound when turning not all the time also a slight vibration when driving.an the new rotor has a wear marks on it.!! also has a new bearing..same ball jounts and tie rods.
Old Oct 2, 2011 | 05:17 AM
shorebird's Avatar
shorebird
The description of movement in all directions makes me believe that there is a bearing problem.
Who did the bearing?
Old Oct 2, 2011 | 05:34 AM
m@m's Avatar
m@m
ME china made
Old Oct 2, 2011 | 07:10 PM
shorebird's Avatar
shorebird
Where is the point of movement?
Old Oct 3, 2011 | 03:21 AM
m@m's Avatar
m@m
i jack up the frt off the the ground and grab the tire like as if i was checking ball jounts and tie rods the wheel moves no matter where i grab the tire from any angle also the rotor !!
Old Oct 3, 2011 | 05:50 AM
shorebird's Avatar
shorebird
OK!
No movement of the actual suspension parts.
There are 7 points of contact.
2 points where the Lower arm meets the frame.
2 points where the Upper arm meets the frame.
The Lower Ball Joint.
The Upper Ball Joint.
Tie rod end.
If there is no movement in any of those points then that leaves the hub.
I think that you have a failing hub/ Bearing Assembly.
Part #1104.
Old Oct 6, 2011 | 05:16 AM
m@m's Avatar
m@m
did what you said looks like the hub assy. picked up a moog assy from advance auto 224.00 and a cv 60.00 new some kind of clunking going on plus boot ripped .called HUBBEARING.COM to see what they would say about the china assy.that i payed 116.00 of them in april with 2000 miles on it they where very helpful long story short getting back my 116.00 with free shipping!! when i ship back the hub.
thanks shorebird
Old Oct 6, 2011 | 06:16 AM
shorebird's Avatar
shorebird
You're welcome.
Update us when you have news.
Old Oct 6, 2011 | 06:35 PM
m@m's Avatar
m@m
any tricks on getting off the 6 cv bolts letting them set over night with PB blaster.
Old Oct 6, 2011 | 07:49 PM
shorebird's Avatar
shorebird
I would use a breaker bar to loosen the CV bolts
Old Oct 7, 2011 | 10:36 PM
m@m's Avatar
m@m
didnt have a breaker bar but used a pipe 2 foot long that sliped over my 1/2 inch rachet and used large pair of vise gripes to hold the cv from moving went slow and all 6 bolts came off without striping ! then i had to take off the actuator to slipe the new cv into place and there is a small peice of plastic that holds the gear into place gone replaced this only 2000 miles ago from dealer $120.00 going to dealer tomorrow for new one is there no end ?? the only thing keeping me from trading it is the hurricane film ..
High_HP
Jul 30, 2013 05:07 PM
69ford99
2004 - 2008 F150
Aug 28, 2011 10:52 AM
clhart426
Oct 21, 2009 08:41 PM
jmoo8508
1983 - 2012 Ranger & B-Series
Jan 1, 2004 08:55 PM
markus
Dec 30, 2003 07:06 PM
