Advice needed
Old Oct 1, 2011 | 05:44 PM
IrnRngr's Avatar
IrnRngr
Advice needed
I have a 90 F-250 4x4 reg cab 351w auto trans..I want to lift it 2in and am putting a plow on it. Whats the right/best way to go about doing it and what company has the right product??? Thanks for any help..
Old Oct 1, 2011 | 07:20 PM
Edgethis's Avatar
Edgethis
Are you asking for help on the lift or the plow?
F250/350 Extra Heavy Duty Front Springs, Stock (Pair)
Old Oct 1, 2011 | 09:58 PM
IrnRngr's Avatar
IrnRngr
Advice on the lift...thanks
Old Oct 2, 2011 | 05:12 AM
Edgethis's Avatar
Edgethis
I didn't really see a 2" lift for the 250s. Those springs I linked are meant for plows/winches as they are a much beefier spring then the stock F250. They will prolly cause your truck to sit a bit higher.
Only lifts I can find start at 4" for your truck.
Old Oct 3, 2011 | 04:28 AM
IrnRngr's Avatar
IrnRngr
thanks again
Old Oct 3, 2011 | 09:55 AM
nstueve's Avatar
nstueve
shackle flip in the back will give you 2.5-4in depending on how you do it. if you do a 4in lift on the front and a shackle flip in the rear I would think with the plow weight you'd be sitting about even...
There are "add-a-leaf" kits that will boost the front end 1-2in. This basically "levels" the truck, but once you get the plow on it will pull the front end back down any extra you would have gained.
BRay09
Offroad & 4x4
Jan 7, 2009 06:06 PM
Gmeanie
Mar 3, 2008 11:16 AM
blindboyth
Jan 30, 2008 09:43 PM
viperbluelx
Jun 16, 2007 06:04 PM
