Hhhmmmm I'm wondering?
Old Oct 1, 2011 | 03:37 PM
Machinegunmike's Avatar
Machinegunmike
Hey fellas, besides the obvious warranty plate which is fastened to the driver door which other identifying factor is there to determine if I have a 64 f100 or f250?? I'm starting to think the doors have been swapped.
Old Oct 1, 2011 | 04:21 PM
davewave649's Avatar
davewave649
should be stamped on the frame rail too, i believe passenger side.
Old Oct 1, 2011 | 05:01 PM
jowilker's Avatar
jowilker
Easy on that, look at the wheels, a 100 has 5 lugnuts, a 250 has 8
John
Old Oct 1, 2011 | 07:34 PM
Machinegunmike
Thank you John
Old Oct 1, 2011 | 07:51 PM
bertha66's Avatar
bertha66
John
That is the fastest way to tell John, good advice.
Old Oct 1, 2011 | 08:45 PM
gangstakr's Avatar
gangstakr
What if 3 out of 8 "LUGNUTS" on each wheel have fallen off, but the wheel studs are still there is it a 100 or a 250?
Old Oct 1, 2011 | 10:52 PM
66CustomCab's Avatar
66CustomCab
Old Oct 2, 2011 | 02:34 AM
Jetcopterpilot's Avatar
Jetcopterpilot
What if the PO has done a brake swap and gone to the 5 lug set up? the other way is to count the leaves on the rear springs.. then chat with numbersdummy, he can tell you the exact count.. Dave is correct though the VIn should be stamped on the top of the right side frame rail! it make take some scrubbing to fin it though!
Old Oct 2, 2011 | 03:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964 F100 2WD's have 5 lug wheels on a 5.50" bolt circle / 11" x 2" front brakes / 11" x 1 3/4" rear brakes / 6 leaf front springs / 5 or 6 leaf rear springs.
1964 F250 2WD's have 8 lug wheels on a 6.50" bolt circle / 12 1/8" x 2" front & rear brakes / 7 leaf front springs / 7 or 10 leaf rear springs.
Old Oct 2, 2011 | 03:25 AM
Jetcopterpilot
Thank You Bill for nailing that down I knew that you would...... My 64 F250 had 13 rear leaves, but it was apparent that the PO did an add on to the stacks.... I removed 2 on either side, added air shocks, and it rides much better...
Old Oct 2, 2011 | 08:57 AM
bertha66's Avatar
bertha66
Vin# on the title would start with F10 for a F100 and F25 for a F250, for 2wd trucks.
jwitty
Dec 19, 2017 06:14 AM
Jbkurtzer
Jul 21, 2015 08:07 AM
emeraldcoupe
Jan 12, 2010 02:19 PM
jpoesq1
Aug 17, 2008 12:59 AM
Boomtown
Nov 14, 2004 05:46 PM
