2nd EGR cooler/need help
Old Oct 2, 2011 | 02:00 AM
Hurricane67's Avatar
Hurricane67
so i guess im gonna put the delete kit on it and put in a new cooler, but how long can i drive it before it jacks my whole motor up?
Old Oct 2, 2011 | 08:23 AM
U.P. Builder's Avatar
U.P. Builder
If you have coolant loss, puking or white smoke and suspect the egr cooler has failed I would not drive it at all. You are risking blowing the head gaskets.
Old Oct 2, 2011 | 01:31 PM
2004SUPERDUTY's Avatar
2004SUPERDUTY
If you dont already have blown gaskets you probably will sooner or later.. I would take the heads off and have them checked and reinstall with arp's and new ford gaskets.. i learned the hard way.. after my second egr cooler popped in 56k the head gaskets starting leaking within a year after i had deleted the egr cooler so i then had to pay to get them replaced.. do it all at one time and get it over with..there are also a few other things to check/replace while you are in there.. the techs on here can tell you better than I can about those.. just my 2 cents
Old Oct 4, 2011 | 07:18 PM
Young Gun's Avatar
Young Gun
Originally Posted by cheezit
seen a few. not many though
Originally Posted by m-chan68
I have only ever seen ONE truck that needed to have both coolers replaced twice, but it was an E-Series that the owners were very guilty of using for very short distance drives and frequent engine shutdowns or extended engine idling, resulting in a VERY badly carbon clogged up second EGR cooler.
Just my .00002 from the outside looking in. If I didn't know anything about my truck and it failed so I took it to the dealer and they charged my 2K to fix then 20K miles later the same problem happened... I may not take it to the same place to get it fixed. I'm not trying to disprove either of you its just my thinking
Old Oct 4, 2011 | 07:40 PM
cheezit's Avatar
cheezit
20k is not right after.. my thinking here to the question was right after / shortly there after. once again IMO 20k miles is not it.
Old Oct 4, 2011 | 07:56 PM
Ian123's Avatar
Ian123
Well you won't ever see mine but you might hear of it being number two because all my trips are short. I don't turn the truck on and off frequently or idle extensively so maybe that will save me
Old Oct 4, 2011 | 08:30 PM
cheezit's Avatar
cheezit
I also put 3 in one truck with in 1000 miles... that was my fault I followed the stupid pinpoint test for p012f. I contacted tech support was advised to repalce it each time. lessons we learn about how stuff works. needless to say p012f is not exactly as it seems to be 100% of the time.
Grant-Dieseltech
Nov 22, 2014 12:05 PM
emmagator
Jun 3, 2013 08:00 AM
04scurs
Mar 19, 2011 05:02 AM
Cobra93svt
Feb 1, 2011 05:48 AM
046.0PSD
Jan 7, 2010 02:17 PM
