i am a bit desprate here, and i need some help. i recently was given a 223 that is a fresh rebuild, and has the three speed bellhousing on it. my delema is to get a warner T-98 to fit the engine. i have not found much info on this swap here on the internet. i have heard many diffrent things about Y-block bells fitting 223s and also 8BA flathead bells fitting these also. i have a few T-98s, one of which is bolted up with a Y block in a 53 frame. so what fits and what dosent??
