Sponsored by: Real Truck
removing pitman arm
Old Sep 29, 2011 | 09:27 PM
2wdluke's Avatar
2wdluke
removing pitman arm
Hey guys, Im a new member but long time reader. I have learned so much from this forum..Any ways iv got a 2000 2wd f250 and i just added a 6'' lift. Im having a hard time removing the pitman arm. i beat the crap out of the pickle for and no luck. someone told me there is different sized forks. Does anyone know if this is true?any tricks or ideas to get that thing loose. thanks for any help or advise.
Old Sep 29, 2011 | 09:33 PM
Pili's Avatar
Pili
you need a pitman arm puller looks like this http://tonedeafjoke.files.wordpress....11/07/pa80.jpg. most parts stores rent them
Old Sep 29, 2011 | 09:48 PM
2wdluke's Avatar
2wdluke
Iv got the tool to remove the arm from the gear box, im having a hard time removing the drag link from the pitman arm. and i really screwed up the rubber seal. can thoes be replaced without replacing the hole drag link
Old Sep 30, 2011 | 12:44 PM
mwsF250's Avatar
mwsF250
When it comes to suspension work, nothing beats the right tool! And on heavier duty trucks like these, the right tool gets even more critical.
First choice if it will fit:
Amazon.com: OTC 7315A Universal Tie Rod End Remover: Home Improvement
Second choice (only because they are not as strong):
Amazon.com: OTC 6297 Ball Joint Separator: Automotive
Tip: Don't waste the money on el cheapo chinese knock offs... They are usually so weak they break before getting the job done.
There are also smaller versions of the style of press Pili posted that will work.
Pickle forks are my last resort as they tend to destroy the seal and the ball joint. You may be able to find just a seal, but take a close look at the ball before you bother. If any scrapes or dents, replace it.
Old Sep 30, 2011 | 05:44 PM
Layson's Avatar
Layson
You put a little heat to it (mini torch) uniform around the arm and it will come right off with a puller.
Old Sep 30, 2011 | 06:30 PM
shorebird's Avatar
shorebird
A visit to the parts store can snag the tool you need.
A refundable deposit can get you the tool for a few hours or even days.
jerryst
Nov 15, 2016 09:10 PM
Seanosu
Feb 29, 2016 11:34 AM
jasonious
Mar 8, 2011 04:32 PM
FLJ
Feb 15, 2009 07:03 AM
duback66
Dec 15, 2007 08:15 PM
