roller and none roller motors
Old Sep 29, 2011 | 03:26 PM
jdmcivic23's Avatar
jdmcivic23
How can I tell the difference in a 302 roller motor and a 302 none roller motor by just looking at it.
Old Sep 29, 2011 | 03:33 PM
lew52's Avatar
lew52
You really cant tell by just looking at the motor , the 94 up are rollers , they also have the 351 firing order , some 92-93 had a smaller roller cam but with the standard 302 order , all HO motors are rollers....Lew
Old Sep 29, 2011 | 05:13 PM
Conanski's Avatar
Conanski
There is no way to know for certain without having a look inside for the dogbones around the roller lifters, and you don't need to remove much more than the valve cover to see if these are present or not.
Old Sep 29, 2011 | 08:34 PM
jdmcivic23's Avatar
jdmcivic23
thanks guyz
thanks for the info im a honda guy that owns a 94 f150 an love it so im learning thanks again guyz
Old Sep 29, 2011 | 10:06 PM
Conanski's Avatar
Conanski
If you got a V8 your truck should have a roller motor, by '94 everything was.
Old Sep 30, 2011 | 08:15 AM
SCRebel's Avatar
SCRebel
In a roller motor the distributor has a steel gear, flat tappet has a cast iron gear.
needs more mudd
Jul 13, 2012 06:26 AM
fontime
Feb 3, 2012 11:24 PM
Jrock909
22
Feb 7, 2007 10:32 PM
Sanders
Apr 25, 2005 04:34 PM
david00f150
27
Mar 11, 2005 09:02 AM
