Sponsored by: Real Truck
Help 4wd problem
Old Sep 29, 2011 | 02:07 PM
kita999999's Avatar
kita999999
Help 4wd problem
ive have an 03 f350 4wd that the trans case will not lock in 4wd,there is no power to the accuator motor, no power to the on dash s/w, all of the fuses are good. i have been told that there is a module? between the dash s/w and the fuse box that the power goes through, no one can tell me where it is what it looks like or what it does so any info would be great.
Old Sep 29, 2011 | 03:29 PM
dchamberlain's Avatar
dchamberlain
Read the following post. It is something I wrote some time ago to help in diagnosing transfer case shift problems.
https://www.ford-trucks.com/forums/1...l#post10605244
Old Sep 29, 2011 | 03:47 PM
kita999999's Avatar
kita999999
thanks loads great info now the only gray area is where is this 4wd module located that you refer to, thanks again
Old Sep 29, 2011 | 03:50 PM
dchamberlain
The 4WD control module is behind the glove box.
But I wouldn't even consider going there until you've exhausted ALL other possibilities.
TooManyProjects
Dec 21, 2018 11:13 AM
neemeth
Nov 13, 2014 07:17 AM
HenryII
Dec 7, 2012 11:40 AM
mckinnep
Jun 29, 2004 03:23 PM
bigric
1978 - 1996 Big Bronco
Mar 20, 2003 11:02 PM
