turning up my IP.
Old Sep 28, 2011 | 11:22 PM
Skyblaster2000's Avatar
Skyblaster2000
turning up my IP.
I have a 93 F-250 7.3 Diesel and I was wondering how much should I turn up my injection pump? I really want to blow some smoke but I don't want to ruin my motor.. Any suggestions????
Old Sep 28, 2011 | 11:31 PM
91dirtydiesel's Avatar
91dirtydiesel
Better get a pyrometer first
Old Sep 28, 2011 | 11:34 PM
LSO1123's Avatar
LSO1123
Well first off blowing a bunch of smoke out is not a good thing. Some black smoke under hard exceleration or under a load is fine but if you're "rolling coal" all the time then you're just wasting fuel and probably running some high exhaust temps. If you don't have a pyrometer, don't mess with it until you get one unless you want to replace some melted pistons. Once you have a pyrometer, I would start out with one flat and see how you're exhaust temps do. A flat is basically turning the hex wrench one "flat side" at a time. You would probably be okay with 2 or maybe 3 flats but I wouldn't risk it without a pyrometer.
Old Sep 28, 2011 | 11:39 PM
91dirtydiesel
Also would be good to know if your turbo or not, and if your looking for power...or just a cloud of black
Old Sep 28, 2011 | 11:46 PM
LSO1123's Avatar
LSO1123
That's true, if you have a turbo you can more than likely get away with turning it up a little more.
Old Sep 28, 2011 | 11:50 PM
Skyblaster2000
Ya everybody is telling me to get a pyro so I better.. Are they hard to hook up??? and yes it has a turbo.
Old Sep 28, 2011 | 11:55 PM
LSO1123's Avatar
LSO1123
Nope not hard. Just drill and tap your driver's side exhaust manifold behind the #8 cylinder for your probe then just hook up the electronics. I have mounted the probe in the down pipe about an inch from the turbo outlet but if you do that you can add about 200-400 degrees to what your pyro is reading at any given time.
knapikmichael
13
Feb 13, 2011 04:36 AM
deceptichop
48
Sep 9, 2010 04:51 PM
Fordownsall
Jun 15, 2010 09:41 PM
ghunt
General Diesel Discussion
17
Sep 10, 2008 08:12 AM
scottie2hottie
Sep 12, 2006 10:18 PM
