Dually conversion
Old Sep 28, 2011 | 10:13 PM
PowerStroker94's Avatar
PowerStroker94
Dually conversion
Hey guys, I am looking to do a dually conversion on my 95 F250. I have a friend donating me the dually axle from a 97 ford box truck so I have the rear covered, but for the front, do you need a special axle for the dually rims, or can I just throw on any old dana 60 from an f350 like I planned? Thanks in advance guys.
Old Sep 28, 2011 | 11:33 PM
chicagodragon's Avatar
chicagodragon
check the width on the box truck axel, i think it may be different than a regular dually axel
Old Sep 28, 2011 | 11:42 PM
joe_13894's Avatar
joe_13894
The axle from a chassis cab has a narrower spring perch spacing. If you use that axle, you will have to cut them off and weld them on farther apart.
You can use the D60 DRW hubs on your D50. You just pull the hubs off the spindle and swap the DRW hubs on. The base of the spindle is not the same on the D50 and D60, but from the base out they are identical.
Old Sep 28, 2011 | 11:55 PM
chicagodragon
i think the back spacing on cab chassis rear axels are differnt also, not 100% sure, but at least check
Old Sep 28, 2011 | 11:59 PM
bad12jr's Avatar
bad12jr
I would leave the wheels on the front regular. Eagle makes a nice set of dually wheels that are similar to alcoas and the make srw to match them.
Old Sep 29, 2011 | 07:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
you will need a dually rear from a pickup. a cab chassis truck rear will not fit in a pickup without cutting off and re-welding the spring perches 3 inches outbound, and once you do that, you will not be able to use dual wheels because the springs will be too close to the wheels.
Old Sep 29, 2011 | 02:55 PM
joe_13894's Avatar
joe_13894
So is a chassis cab axle narrower flange to flange than a DRW pickup axle?
Old Sep 29, 2011 | 02:56 PM
joe_13894's Avatar
joe_13894
I'm not understanding how that would work. Part of the point of converting the front axle is so that you can have one spare that will fit in any of the 6 positions.
Old Sep 29, 2011 | 04:18 PM
tjc transport
i ain't rite
Originally Posted by joe_13894
So is a chassis cab axle narrower flange to flange than a DRW pickup axle?.
the few i have dealt with were, because the dual wheels make up the difference in the overall width of the axle for greater stability..
the cab chassis trucks like you would find a box on have a 33 inch wide frame, and the pickup has a 37 inch wide frame after 1978 model year.
Old Sep 29, 2011 | 05:56 PM
bad12jr's Avatar
bad12jr
I see your point. But you will have two left over single wheels. Keep both for spares. Could always run a single on the rear it there was a flat. I like the bigger foot print in the front personally.
Old Sep 29, 2011 | 06:03 PM
joe_13894's Avatar
joe_13894
OK, you've lost me there? I thought the DRW pickup axle and the DRW chassis axle were the same width, just the pickup axles had a different perch position because of the frame difference.
Old Sep 29, 2011 | 06:08 PM
bad12jr's Avatar
bad12jr
Cab and chassis is narrower axle.
Old Sep 29, 2011 | 09:30 PM
Brown Falcon's Avatar
Brown Falcon
Cab and Chassis rear axle is 4" narrower overall than a SRW axle, regular Dually axle is 4" wider overall than a SRW axle
I did the DRW to SRW swap on mine so I can verify that...
Old Sep 30, 2011 | 08:57 AM
joe_13894's Avatar
joe_13894
I had no friggin clue about that one.
That would make it impossible to put a truck camper on a DRW utility body unless the camper is above the level of the wheel wells.
Ben L
19
Feb 7, 2019 07:57 AM
Ford4Life7.3
13
Jun 10, 2013 10:20 PM
ginoholt
Jan 19, 2013 06:44 PM
bghnkinf250
Jan 20, 2011 01:00 PM
