To pull the heads off the 2005 F350, I had to disconnect the banjo bolt fuel fittings. To reassemble, I need new copper banjo washers. Does anyone know the part number or have a website or reference I can consult to determine the correct replacement? Even a like to where I could purchase them would be welcome as my local auto parts store was clueless.
Also, I had to disconnect the AC lines, which say to replace the rubber o-rings. I'm unsure of the exact size or specs to purchase or who to order them from. Once again, the local auto parts store was unable to locate suitable replacements.
Fuel line crush washers W303659--requires 2 per banjo--comes 4 per package. These are the composite's, not the coppers. FWIW--you can probably reuse the copper washers. They may or may not leak. I've reused them several times. I don't know about the AC o-rings. I bought an assortment from Autozone a few years back and use them as I need them. Those I WOULD replace every time.
