Brake Help
Old Sep 27, 2011 | 07:55 AM
02stroke's Avatar
02stroke
Brake Help
Ok last December I replaced pads, rotors, and fron calipers. I just checked my brakes and the rear drivers side rotor is grinded apart on the inside. This is the second time this has happened. Has anyone had this problem? Its like the caliper on the rear is grabbing too hard and tearing apart the rotor. Help
Old Sep 27, 2011 | 07:57 AM
timmyboy76's Avatar
timmyboy76
i'd "search" the forum, in regards to the stuck slider pin in the caliper
Old Sep 27, 2011 | 02:46 PM
BendixAnswerMan's Avatar
BendixAnswerMan
I agree with the issue of stuck pins in the caliper. When they are removed the bores need to be perfectly clean and the boots in good shape. The pins should be replaced if there is any corrosion or pitting on them. Use a good high temp synthetic brake lube when reassembling the caliper and pads. Rotors are pretty tough. They will usually be the symptom of an issue and not so often the problem. If the caliper cannot slide freely, there will be excessive wear on the rotor because the pad cannot release properly.
Old Sep 27, 2011 | 03:13 PM
DemonRace6's Avatar
DemonRace6
Hi!
I agree, do a search for it first. Here is Guzzle's page though, he does the front pins in here.
I have never looked at my rear pins, I assume they are the same as the front...
PEG
2004 - 2008 F150
Jul 22, 2019 07:32 PM
f1fred
Feb 19, 2010 06:32 PM
Saber123316
Jul 15, 2008 05:01 AM
DAMSLandscaping
Jun 13, 2007 07:37 AM
blueeyes2478
Aug 4, 2005 03:57 PM
