Wiring issues
Old Sep 27, 2011 | 04:36 AM
Deviant95's Avatar
Deviant95
Wiring issues
Hey everyone, this is my first post so if i mess up let me know. I just picked up an 86 F-350 and it needed some work. I already got the carb put in and it works but a problem that the original owner had comes up still. After running the truck for about 1 mile or so it just shuts off. The original owner said there's potentially a short in the wiring going to the starter solenoid. If anyone knows how to fix this please let me know.
Thanks
Old Sep 27, 2011 | 09:22 AM
1986F150six's Avatar
1986F150six
Hey Deviant95,
Welcome to the forum!
You might want to start off by telling which engine you have. When it shuts off, can it immediately be restarted? Are there any other symptoms, like gauges not working or the smell of gas?
Old Sep 27, 2011 | 01:56 PM
TheKirbyMan's Avatar
TheKirbyMan
It could be the ignition module. I'm not sure but it may be on the side of the distributor, when they get hot they start acting up.
Old Sep 27, 2011 | 02:17 PM
kedwinh's Avatar
kedwinh
My 85 300/6 did that when I got it, ran until the motor warmed up then stopped. Was the ignition module mounted on the side of the distributor breaking down when hot that was causing it. Replaced the module and not a problem sense.
Old Sep 27, 2011 | 04:15 PM
TheKirbyMan
I think there is a kit to relocate the module to the fender. Or perhaps it could be relocated with a little work.
Old Sep 27, 2011 | 04:54 PM
Deviant95's Avatar
Deviant95
its a 460 big block, and i cant start it anymore cuz the battery died. but when the battery wasnt dead i could start it. and then it would die a lil while after and then start right up again. but what i noticed is that the starter solenoid would get kinda warm.
Old Sep 27, 2011 | 04:56 PM
Deviant95's Avatar
Deviant95
and there arent any other symptoms. but another issue im facing is that the odometer hasent worked since 58,XXX miles so i have no idea the how miles are on it. is there a way that could be fixed?
Old Sep 27, 2011 | 06:39 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There are ways to fix the odometer.... or you could swap it for another one.
Re: your truck shutting off once it warms up.
You will see an aluminum box about 5X5X1.75" on the drivers side inner fender well.
There are three 10mm bolts underneath, inside the wheel well.
Unscrew these and look at the bottom of the box.
Is the plastic filler all bubbly or running out?
If so, your ignition module is likely shorting out.
Old Sep 27, 2011 | 07:21 PM
Deviant95's Avatar
Deviant95
ok when i get the truck back from my cousin whos putting the tires onto new wheels and aligning them ill take a look at it.
Old Oct 22, 2011 | 11:33 PM
Ranger350's Avatar
Ranger350
Sir, run your truck at idle. If the coil is hot to the touch, that's your problem. Once it cools it runs again.
Old Oct 23, 2011 | 02:36 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Ignition module is a very comon problem for the type symptoms described. Especially the TFI-IV with distributor mounted module.
There was a kit to relocate this module, since obsolete. Seen a few in the junkyards, if interested on relocating it to the firewall.
Old Oct 23, 2011 | 02:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't think a F-350 460 had a TFI in 1986.
But whatever module there is could very well be failing when warm.
Old Oct 23, 2011 | 02:57 PM
81-F-150-Explorer
DS-II modules had simular overheating problems, but not as severe.
aic
Apr 6, 2020 12:32 PM
tylert1976
30
Dec 8, 2012 01:07 PM
wagonerkl
Feb 27, 2009 05:51 PM
Lngbeard
Jul 2, 2008 10:25 AM
Pick em up
Electrical Systems/Wiring
Sep 20, 2003 05:36 PM
