I have an exhaust leak that I cant seem to find. Im pretty sure its up around my drivers side manifold. With the tire off and my head in the fenderwell I can hear the leak clearly. Using welding gloves I put my hand on each exhaust port but the noise didnt change and its not leaking at the cat pipe joint either. Looking at the manifold there are no black marks, flame licks or any signs of a leak. All the manifold studs are there as well. The truck is quiet at idle and light cruise and only makes the noise when revved hard or under a heavy load. I dont want to go through the hassle of swapping out the manifold if I dont have to.
