window motor issue
Old Sep 26, 2011 | 04:30 PM
fordtough81's Avatar
fordtough81
window motor issue
Im trying to fix the window motor on my 86 f150 i got the motor removed and hooked up the one i just got from the junk yard and it will only let the window up when i press down it does nothing i also checked the motor that came with the truck and the same thing happened so i assume there is a problem in the wire harness. any advice on this issue would be greatly appreciated
Old Sep 26, 2011 | 04:32 PM
kedwinh's Avatar
kedwinh
Have you checked the switch? Maybe hook it up backwards and see if it does the same thing.
Old Sep 26, 2011 | 05:12 PM
fordtough81
I tried that but it still only works in one direction
Old Sep 26, 2011 | 05:19 PM
kedwinh's Avatar
kedwinh
If the switch works and both motors do the same thing I would look for power to the "down" side of the switch or a bad ground.
Old Oct 16, 2011 | 04:38 PM
exparte99's Avatar
exparte99
I have the exact same problem! Motor works, switch works but motor only goes in one direction. Anybody have a resolution to this issue?
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
Truck Guy99
Sep 5, 2013 11:03 AM
turbo740922
1997 - 2003 F150
Aug 10, 2011 02:28 PM
hugo0612
Sep 17, 2007 10:09 PM
cheetoh
May 26, 2005 07:09 AM
