ignition switch help needed ASAP
Old Sep 26, 2011 | 12:26 PM
NW 150's Avatar
NW 150
i need to know how to get the pos off because i am absolutely sick of not being able to work on my truck, when i turn the key and nothing happens. I know it's the switch, and I need to know as soon as possible how to get the junk that's in there now out and replace it. It's the bigger grey section behind the dash right after the piece where the key goes into.
Old Sep 26, 2011 | 12:38 PM
jim collins's Avatar
jim collins
Put the key in the ignition,on the face of it there is a small hole. I take a large paper clip and straighten it out,the push the end of the clip in the hole at the same time turn the key to the left a little more and you can feel it release . Pull the tumbler out with the key still in it ,then unscrew the lock ring on front,that releases the complete unit. If you intend to reuse the key and tumbler ,don't turn it,just lay it back out of the way. When you get the new switch in ,push the key with the tumbler in and turn it to the right,clock wise. I think i got it correct to you.
Old Sep 26, 2011 | 01:33 PM
jsutton's Avatar
jsutton
I'll just add that if you need to get the whole thing out, you have to unscrew the chrome ring that is around where the key goes. It should have a slot in it, just put a flat head screw driver on it and tap the screwdriver in the direction to loosen (unscrew) the ring. Then the whole thing comes out from behind dash.
EDIT: Sorry I just skipped right over the part where jim already said to unscrew the lock ring.
Old Sep 26, 2011 | 08:46 PM
NW 150's Avatar
NW 150
thanks guys!
63beater
Apr 18, 2009 08:19 AM
baggs1977
Sep 5, 2007 12:31 AM
93Sunplex
Feb 27, 2007 06:17 PM
Nicholas112
Bronco II
Nov 18, 2004 07:23 PM
dsohns
Aug 15, 2004 09:04 AM
