Still asking questions about F-150 lift!
I have a 01' F-150 Supercrew and I want to lift it, is it possible to lift it 6" and not crank the torcion bar? I would like to level the front end up with the back is the a way to do that with putting a suspension lift in? I would like to stay away from a body lift if at all possible. I am wanting to clear a 35x14.5 with a 4 5/8" backspacing on a 10" wheel. Someone please help me with my delima.
You could put on a 6" Fabtech that I think will give you what you are looking for: lift, level, clear 35"s. Here are some pics that might help give you an idea of how they look installed:
Ford 1/2 Ton Pics
You can also clear 35" tires with a 5" RCD I believe.
Or, if you wanted to run a taller tire Donahoe Racing will have a 7" EDGE lift available later this year.
The only thing I am not sure of with these is the 14.5" wide tire.........I've only seen 35X12.5 tires on the 150s.
Hope this helps.
Ford 1/2 Ton Pics
Hope this helps.
Leatherneck W5
11-22-2016 11:51 AM
