Sponsored by: Real Truck
Sloppy Shifter questions!!!!!!!!!
Old Sep 25, 2011 | 06:40 PM
knightrider955's Avatar
knightrider955
Question Sloppy Shifter questions!!!!!!!!!
My 03 has a lot of play in the shifter. So I dropped the steering column to have a look. It appears that there is a shifter tube and a few plastic bushings that have some play. Is this a common thing in these trucks? Is this something I can repair myself? I would love some tips from anyone that has done this.
Old Sep 25, 2011 | 07:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
An a ****er tube ?
Old Sep 26, 2011 | 07:54 AM
samsdad02's Avatar
samsdad02
yes you can do it yourself. the biggest problem I had was finding a parts guy who knew what I was talking about. you also need to check the 2 torx bolts underneath. lay down on the floor looking up and wiggle the shifter follow it and you will see 2 torx bolts along the shaft.
Old Sep 26, 2011 | 08:43 AM
knightrider955
Ok thanks. I have the part numbers for everything so Im hoping I shouldnt have a problem. I was told I have to remove the airbag but I dont see why. I am gonna remove the negative cable though.
Old Sep 26, 2011 | 01:27 PM
4x41977's Avatar
4x41977
Let us know what ya find out. My 03 has the same problem
fotoboy
27
Mar 3, 2020 06:30 PM
AliceSML79
29
Jul 5, 2015 11:33 AM
tiopet
Aug 7, 2012 05:16 AM
mustangcrew
1997 - 2003 F150
May 13, 2008 06:06 PM
