Engine misfire help!!
Old Oct 8, 2011 | 12:31 PM
aquanaut20's Avatar
aquanaut20
If you think it is an injector or fuel delivery issue, that can be determined with a fuel pressure test (all 5 tests), a noid (check trigger signal) and DMM (confirm coil condition). Philip
Old Oct 9, 2011 | 08:38 AM
deniser26's Avatar
deniser26
thanks for all the input guys! I will try to find someone who can try these options!
Old Oct 22, 2011 | 07:30 AM
deniser26's Avatar
deniser26
just wanted to update this thread~what was supposed to be a $5000.00 problem was fixed with a simple plug wire. $65 and we are back in business! only issue now is a "squeaky sound" when I accelerate. not sure if it is belt or pulleys....
Old Oct 22, 2011 | 11:14 AM
kbsupercrew's Avatar
kbsupercrew
Do the belt on ,belt off rev in nuetral test only for a couple revs of course and if not the belt or any of the accy pullys, a broken exhaust manifold bolt will do this sound, the factory steel gaskets will vibrate with the air pressure rushing by causing a sqeal noise good luck
tonefordays
Apr 24, 2015 08:19 PM
diesel_s
Dec 8, 2014 09:44 PM
2oo1 4x4
1997 - 2003 F150
May 22, 2014 07:04 AM
Cfdchf
1978 - 1996 Big Bronco
Oct 28, 2004 06:20 PM
Bigjond27
Oct 27, 2004 04:09 PM
