1978 - 1996 Big Bronco
Checking Injectors
Old Oct 25, 2004 | 10:53 PM
Cfdchf's Avatar
Cfdchf
Checking Injectors
My 90 302 has a miss and I have changed Rotor, Cap, Wires and plugs. It still misses on #7 cylinder Could this be a injector and How do I check it to see if it is working properly. Also the plug that I pulled from that Cyl. is slightly gray at the electrode tip. Thanks Don
Old Oct 26, 2004 | 09:39 AM
greystreak92's Avatar
greystreak92
Swap an injector from another cylinder. If the problem moves, its the injector. If not you are dealing with some other headache.
Old Oct 27, 2004 | 06:52 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
Check to make sure the plug has spark while you have it out.
One thing you can also do is crank the motor with the coil wire off and then pull out plug # 7 if its not wet with gas you most likely have a bad injector.
Had one go bad on my 90 had the same symptom's you have.
If you do need one take the old one with you when you go to get one.The darn dealer sold me one for a 351 and I have a 302 !
Old Oct 28, 2004 | 04:21 PM
Cfdchf's Avatar
Cfdchf
It seems like the injector might be somewhat working at higher RPM'S but below about 3000 it is missing. Is this normal for a injector. I have a couple cans of seafoam in it but it isn't helping.
Old Oct 28, 2004 | 06:20 PM
greystreak92
If the coil is dying in the injector, yes, it could be an intermittant problem. Could be that its just not as noticable at higher rpms.
johnlynn6
1997 - 2003 F150
Mar 11, 2011 08:09 PM
f100guy
1997 - 2003 F150
16
Dec 5, 2010 06:43 PM
ORDuneBronco
Jan 10, 2010 08:37 PM
nerider
Modular V10 (6.8l)
Apr 28, 2009 09:06 AM
msmmce1
Modular V8 (4.6L, 5.4L)
Sep 23, 2008 11:30 AM
