pcm question
Old Sep 25, 2011 | 12:04 PM
funzjb1's Avatar
funzjb1
pcm question
how do you test if your PCM or IDM is bad?? I was driving down the road the other day and the truck just shutoff and has not been able to start since. it was running just fine prior except lately in the morning it would act like it had bad fuel. It would run crappy and a few times die but restart after some cranking and then run just fine for the rest of the day. it did this only in the mornings. I thought it might be condensation build up?? When it finally died there was no DTC codes, no CEL nothing not even a stumble or hick up. I checked fuel pressure and its getting 50-60 psi when cranking, I changed the fuel filter about a week earlier, I drained the fuel bowl and the fuel pump refilled it, I cleaned of the little fuel screen( it was plugged) still no start, checked all the fuses, unplugged the IPR and tried it. I have replaced the valve cover wiring harness about a year ago, along with new glow plugs
Old Sep 25, 2011 | 12:11 PM
427 fordman's Avatar
427 fordman
Dumb question maybe, but have you tried the cps? Does your tach move while cranking?
Old Sep 25, 2011 | 01:31 PM
funzjb1's Avatar
funzjb1
I forgot to mention I did just replace the CPS also during this problem and still no start, but the tack does move
Old Sep 25, 2011 | 04:34 PM
DDPJ's Avatar
DDPJ
I just had to have my IDM replaced along with the valve cover gaskets. Truck just up and died going down the road. Would crack, but wouldn't start. From what I found, the wiring to the injectors that run though the valve cover gaskets has been known to fail due to the heat. Ford didn't insulate the wires to well on the originals. This may have shorted and caused the IDM to fail. Ford's OEM IDM was not sealed and has an issue of moisture getting in and causing shorts also. The only code that came up on my reader was a CAM shaft sensor error. It took a good reader from the shop to find the exact problem. If it is your IDM, check online for replacements. I got mine from pensacoladiesel.com
insolution
25
Mar 1, 2011 07:21 PM
59JEEPSTANG
Jan 28, 2011 07:33 PM
ALdieselfan
Jul 14, 2007 10:48 AM
70spoiler
Dec 6, 2005 07:02 PM
CedarKnollQH
Jan 6, 2004 08:18 PM
