CPS Not The Problem - What Next?
What type of code scanner do I need to read this truck (again a 1995 model). I've tried two: Auto-Tech (whose tech support later told me could not scan this vehicle for engine codes because Ford only used the computer for transmission monitoring) and one borrowed from a friend. I believe it was called EZ-Xray. Neither worked. Is there any way to get the Check Engine Light to flash the code? Chilton says no.
Possibly related - About two months ago I had smoke come out of the wiring harness on the front harness where it plugs into the valve cover gasket (passenger side). That connection completely melted. The parts man at the local Ford dealership said he's seen it happen before and that it is really nothing to worry about - usually just a short in the gasket.
I replaced both harnesses inside the valve cover (I messed up the rear one taking the valve cover off). The rear harness on the outside looked fine but the front plug was slightly melted at the first pin. Ford told me that the only way to replace that plug was to buy the entire $1500 wiring harness. I tried the existing plug and it seemed to work so I didn't worry about it. Two months later I'm having this problem.
I'm praying it's not the fuel injectors (big $). Any chance it's the catalytic converter? I assume this vehicle has one.
I wish I could read that dang code....
Seeya Jim
I think it is time to get thee to a mechanic.
Another thought, I've read that the fuel pressure should be between 20 and 60 psi depending on engine speed. If I had 35 to 40 at idle, would that indicate that the fuel isn't getting "out", in other words, it probably is an injector problem. (Fuel filter is new).
Thanks to all.
Don't go to the mechanic and mention that you think the injectors are bad, let him/her diagnose if for themselves. Otherwise, you might pay for new injectors when that's not the problem.
One good thing about working around construction sites - I know some decent diesel mechanics. In fact, the one I use regularly has shown me how to do some stuff myself and has saved me some $$. I think this is over my head though.
I can get it to stay on, but it runs like you describe and the check engine light stays on. Occasionally it smooths out and runs fine, but mostly not. Within the past few months I have replaced the fuel pump and Camshaft Position Sensor. HPOP reservoir is full. Also replaced the fuel line that goes into the bottom of the fuel filter assembly.
I used an AutoXRay scanner--it scanned but found no trouble codes. Let the guy at Autozone scan it with his scanner and again it passed. I'm beginning to think this one's over my head, too.
The mechanic I use shuts down between Christmas and New Year's so he hasn't looked at it yet. I plan to take it over there sometime this weekend. Luckily he's only about two miles away ( half of it on a dirt road) and I can pull it over with my tractor.
I'll post the problem/solution when it's finally resolved....
"What type of code scanner do I need to read this truck (again a 1995 model). I've tried two: Auto-Tech (whose tech support later told me could not scan this vehicle for engine codes because Ford only used the computer for transmission monitoring) "
Well they are wrong. All PSD's are monitored by the computer. You can pull codes, check injectors, and so on. Maybe their tester can't read it but the brain does more than look at the tranny.
One note, even if a harness for the injectors are fried the test comp will say the injector is done. I'd pop the valve covers and pull the wires and look. You know what a fried one already looks like. The wires are normally fried due to moisture. Hit the connections with something that displces water before you reconnect.
Although some scanners say OBD-II is the standard for 1996 and after, Ford had it in these trucks in 1995. Still there may be something out there (probably in the hands of the dealer) that reads a lot more than these generic scanners do.
I had it towed to the Ford dealership where they diagnosed it as a failed injector drive module (OBD code P1298). I had the module replaced and it runs like a top.
However, the wiring harnii (plural for harness?) under the driver's side valve cover were fried. Apparently the same malfunction I had on the passenger side several months ago (described earlier). I didn't notice it because all of the damage was on the inside (on the passenger side it was on the outside also).
I could have probably fixed it myself had I known what the problem was. But I'm still glad I took it to the mechanic. Getting under the driver's side valve cover looked like a little more surgery than I wanted to undertake anyway.
The bad news, still a several hundred dollar repair (while in there he's replacing glow plugs too). The good news, it's not a several thousand dollar repair.
On the previous note about the scanners, I was also plugging into the plug that is just left of the ashtray. I forget what scanner the mechanic said he used, but it apparently worked....
Thanks all.
