Help with Diagnostic Codes
Old Apr 7, 2003 | 02:11 AM
TexasGuy001's Avatar
TexasGuy001
Question Help with Diagnostic Codes
My Check Engine light is on, and I need some help with figuring out these codes. From what my code reader says, it appears that the Hard Code 552 (Thermactor air bypass solenoid circuit fault), and Intermittent or Continuous Codes are 212 (Loss of ignition diagnostic signal monitor signal/SPOUT fault) and 332 (Insufficient EGR flow). I know the SPOUT is related to timing, but I'm not sure why when the codes have been cleared it still comes up. My main question is does the Thermactor air bypass solenoid or valve related to the EGR flow? What is the Thermactor Air Bypass Solenoid and where is it?? Any help is greatly appreciated!
Old Apr 7, 2003 | 05:41 PM
TexasGuy001
I'm worried that driving my truck like this may cause further damage. Does anyone know if it will??
88 f150
Sep 23, 2021 07:55 AM
greystreak92
1978 - 1996 Big Bronco
Mar 6, 2011 11:16 AM
cgl
Nov 1, 2000 02:12 AM
