Coolent Flush
Actually Cat® Extended Life Coolant is strawberry red.
http://www.finning.ca/_downloads/sos...t_pehp4036.pdf
Old green coolant= lots of silicates. everyone agrees, don't use it in a 6.0.
OAT coolant= No silicates.
DexCool came first. It was supposed to last a looong time but doesn't play well with silicone sealers and gaskets. Only for use with vehicles designed to run it. Interesting that Ford lists a compatable product on it's website. It is orange. not sure what if any Ford vehicles use it.
Other formulations came after, cranking down the chemicals (nitrates and phosphates to name a couple) and changing up the additive package to make them more universal, meaning less harmfull to gaskets and seals. This group includes the CAT EC-1.
HOAT coolant= small ammount of silicates. The substitute chemicals used in the OAT are still eating gaskets (and heat transfer rates are down) so it's decided to crank 'em down farther ad add a little bit of silicate back. best of both worlds kind of deal. Lasts a long(er) time and easy on the "soft parts" of the engine. This group includes Ford Gold.
Also there was a change to the base from Ethylene glycol (EG) to Propylene glycol (PG) to make it less toxic. PG is often labeled as "non-toxic antifreeze". PG can get very acid over time (EG) not so much, so that consideration also caused some of the changes to the additive packages of all three types mentioned above (when sold as non-toxic).
Hope this helps a little.
But I wuz gettin confused
At least I can look at a bottle and tell which group it belongs in. I just gotta figure out which group I want to put in my truck
I like What I'm reading about the Final Charge, but it's an OAT with no silicates, borates, nitrates or phosphates and I don't understand how it works.
Also, BMW has some coolant that's is silicate free, phosphate free, amine free, and borate free. It's blue. Same issues for me as the Final Charge.
I got a lot of reading to do.
I've read a lot of thecnical papers last few evenings. Much of it is over my head but there are points made sometimes the layman can understand. I've been looking for info about silicate precipitation and I've seen it discussed in papers dated in the late 1990's and no info on being encouraged by temps. It was discussed as related to coolant in storage and agitation and/or ( ironically) heat was the recommended action. Oh well, the search goes on....
I'm going to do it 1 per year regardless of needing it or not. For me that'll be 1st week of Sept just before hazardous material day at my local transfer station and will be about a 40,000 mile interval. I'm okay with $60 per year extra on my maintenance budget.
Now I can move on to worry about other stuff
Basically, the GOLD coolant has such a little amount of silicate in it, that there is no way it is causing the plugging of coolers. However, the Gold coolant does have a problem with Organics growing inside it with prolonged life and heat combinations.
Basically, it all boils down to this. Don't go 50K or more with your coolant. Do regular flushes and maintain it. There are hundreds of thousands of guys running the Ford gold stuff with zero issues. I was all set to do an ELC swap. But after reading a ton of information, I can't see any real reason to ignore Fords recommendation...well besides the service interval. My plan is to do yearly flush/swaps and run a coolant filter.
My next question would be, what type of coolant do they recommend on their 6.4 and 6.7 engines. If they recommend the Gold stuff, their must be a good reason, if they recommend Cat EC 1, then why would they recommend something else than Gold for the 6.0. Warranty issue? Lawsuit Issue? Who knows, Ford have smart lawer too. So what is behind all this.
6.4 and 6.7 were designed in-house by Ford. Ford engineers got to create all the specs and lubricant requirements. The silicants in the coolant also provide lubricity (real word?) that an ELC doesn't.
6.0 was outsourced. Ford Gold coolant is just ____ coolant rebadged. I can't remember the name. But IH spec'd that initially for the 6.0 and it is still used in some applications.
