Sponsored by: Real Truck
Help...Paint!
Old Sep 24, 2011 | 05:17 PM
Sleepsafe's Avatar
Sleepsafe
Help...Paint!
Not my trucks paint, paint on my truck
Apparently sometime since I washed my truck last I drove over something freshly painted. A crosswalk, lines, hell who knows. I washed my truck today and I have white paint, apparently from some highway lining project all over the right side of my truck. Damn 35 inch tires apparently stick out a ways past the mud flaps. I even have it on the mirror on the right side. Mineral spirits doesn't do too great of a job. Any suggestions? Is this stuff latex? Would Goof Off work?
Old Sep 24, 2011 | 05:21 PM
carltonwebb's Avatar
carltonwebb
I have used goof off for that b4. It worked wonders. My older brother used it on his and it took the paint off (it was a gm though) . I would suggest checking it somewhere it cannot be seen b4 using it much.
Old Sep 24, 2011 | 05:36 PM
DRRXR's Avatar
DRRXR
Thumbs up
I haven't used this but a friend did and said it works.
I have even heard of using oven cleaner Easyoff (r)
Easyoff (r) is a heavy alkaline so if it gets into spots where it cant be removed follow up with some vinegar and water to nutralize it.
If yo use the OOPS I would see what it has in it too, in case is a alkaline as well.
Either one cold damage your paint. Then ther is the razor blade under the edge. and use some bar clay to smooth it out.
I suggest a power washer first.
Old Sep 24, 2011 | 05:40 PM
DRRXR's Avatar
DRRXR
Carlton
Just seen your post
Goof Off | Removes the Tough Stuff
Has a nice list of things it can remove
Old Sep 24, 2011 | 05:42 PM
Sleepsafe's Avatar
Sleepsafe
Way too much to attack with a razor blade...
Old Sep 24, 2011 | 06:08 PM
DRRXR's Avatar
DRRXR
Arrow
Mine was like that with yellow paint too. I pressure washed it and left it. Now I see where some have looked up the state DOT and filed a complaint. some have gotten compensation some have not. I see where the DOT in Pa paid for a repair. But thats it.
You may want to check into that route. It got my attention and you bet the next time I will be digging for thier pockets too. May as well heck its your tax dollars that paid for the road paint.
Just something to think about.
Old Sep 24, 2011 | 08:29 PM
jc8825's Avatar
jc8825
A clay bar treatment should get that paint off.
Old Sep 24, 2011 | 11:56 PM
13firemen's Avatar
13firemen
try some methylhydrate, you grt it at a paint store apply to a rag and wipe it off, great for over spray an sticky residue from stickers
Old Sep 25, 2011 | 12:46 AM
Wisebuck's Avatar
Wisebuck
Bug and Tar remover also has worked fr me and as a last resort brake fluid
Old Sep 25, 2011 | 12:06 PM
GVS's Avatar
GVS
Might be best to leave it on there.Probably better paint than the factory sprayed on. (My '06 is in for paint as I type.My second Ford truck in a row that needed repaint).
Between the paint jobs and non avaliability of manual X/Miss.in current Ford pickups I'm not happy with FMC.
Old Sep 25, 2011 | 12:12 PM
redford's Avatar
redford
FTE Leadership Emeritus
I've taken off line marking paint with some rubbing compound and a rag. Wash the affected area and dry it. Put a little rubbing compound on a clean rag and GENTLY rub it in. You will feel it cutting into the line paint. DO NOT apply much pressure. You will cut through your clear coat and paint if you do.
Once the line paint is removed, go back over the area with your favorite wax.
Old Sep 25, 2011 | 12:59 PM
cartmanea's Avatar
cartmanea
You can use a stronger solvent than mineral spirits. I have used lacquer thinner to take off lacquer touch up paint and it doesn't harm the factory paint.
Old Sep 26, 2011 | 05:22 AM
dbc001's Avatar
dbc001
Acetone cut with water, 50/50 and then aggressive clay bar.
Turbo Dog
Appearance & Dress-Up
Jan 14, 2014 11:06 PM
ratucker3
2009 - 2014 F150
20
Jun 10, 2011 11:11 AM
bayley_dl
Apr 5, 2011 10:50 PM
FordF350Baby
Oct 25, 2007 10:01 PM
theologian
Paint & Bodywork
Sep 21, 2004 08:15 PM
