Air Blower Problem
Old Sep 24, 2011 | 03:35 PM
fordtruck661's Avatar
fordtruck661
Air Blower Problem
Hi guys I just started having a problem with my air blower. Some times It will not work at all weather on A/C or heat. And I find that it happens when i leave it on and turn the truck off. But once I pull the fuse and put it back in it work fine again. I have no idea what is going on
Old Sep 24, 2011 | 05:59 PM
WA.Ranger's Avatar
WA.Ranger
I think there was another thread on a similar problem awhile back, can't remember the particulars though. Someone who might will be along shortly.
Old Sep 24, 2011 | 06:42 PM
Tailgate77478's Avatar
Tailgate77478
Here's a good write-up on the replacement:
https://www.ford-trucks.com/forums/1...d-e-250-a.html
However, I would try replacing the blower motor resistor first...it's $8-$25 for the part (depending on what you buy), and it's only two screws. My guess is it simply needs to be replaced.
But overall, the blower doesn't take long to take out and replace.
Old Sep 25, 2011 | 05:09 PM
fordtruck661
Thanks this is just what I was looking for And i think I will start with the resistor first seeing it is the cheapest.
Old Sep 25, 2011 | 05:53 PM
Tailgate77478
Hope it works! Make sure to post back when you've solved your issue...we like to know, and also, future readers who find the thread on "Search" can also learn stuff.
Old Sep 25, 2011 | 06:12 PM
fordtruck661
Will do I should be fixing it tomorrow because It is one of the things I need to know work when this winter hits! Its no fun being in the cold
jstihl
23
Jun 10, 2017 08:18 AM
cwnitsuj
2004 - 2008 F150
Aug 7, 2013 07:19 AM
F250FarmBoy
13
Mar 30, 2007 05:52 PM
Ekmeian
Aerostar
Nov 27, 2006 11:44 PM
