All I can tell you is that sway control defaults to on all the time. You have to turn it off every time you crank up. I actually felt the brakes release when I turned it off on the interstate. Mileage immediately went up.
I assume there are some kind of rate sensors in the rear of the truck that detect sway.
I know based on my experience that it was activated and I had no trailer connected. I would assume it is there for when you have a heavy load in the bed as well to help prevent rear sway.
As for the 02 Sensor, mine was fine. Not my problem w/ poor economy but could be on others.
Well this is an interesting piece for me, I just did a mpg calculation for what would be a normal drive for me (some saving, some passing, some at 60 mph and some at 70+ and got 14.3 mpg. It has 4500km or 2375 mi on it now.
I have a pretty big cap on it and some weight in the back with my tools and materials but I find this figure a little poo-like. My beloved Excursion (7.3 psd) gave me 16 mpg or so on the same run with the same tool and materials load on board.
I am going to look for the sway control on the menu and see if that makes any difference, never know.
I'm achieving 23+ routinely at 70 MPH. Cruise control is no friend to gas mileage. The computer will run the hell out of the truck to maintain the desired speed.
I noticed that last night! I had it set at 50, I clicked it back on when I was at about 45-46 after pulling away from a light and it took off! I've noticed that the cruise on Ford vehicles always tends to be rather aggressive. Other vehicles I've driven seem to have been a bit more easy on the throttle except when climbing steep hills. Probably doesn't hurt that they were equipped with manual transmissions so that the computer couldn't force the transmission to downshift either.
I have about 230 miles on mine thus far, and in mixed driving (no real highway miles yet) I'm getting 18 mpg on the gauge on the dash. I'm thinking that 20-21 mpg on the highway isn't out of the question. Mine is a 4x2, 157" WB, 3.73 rear.
