1978 - 1996 Big Bronco
Ding, ding, ding... even with key out.
Old Sep 24, 2011 | 02:05 PM
b4hntn's Avatar
b4hntn
If you replace your clockspring do not put the clip to the ignition cylinder flush with the cylinder socket unless you want to be dingy like me. I finally dove back in today while chasing an air bag issues. Here is the little connector. the other picture is with ignition cylinder removed and connector seated where it does not ding with the key out.
Old Sep 24, 2011 | 03:17 PM
Edgethis's Avatar
Edgethis
So it needs to be pushed back and not flush at the end right? Thanks for the tip, mine dings all the time
Old Sep 24, 2011 | 03:28 PM
b4hntn's Avatar
b4hntn
Right.
Thinking about it, you might be able to check it with just an ice pick if you can run through the hole in the plastic and hit the hole holding the cylinder. Of course, put the key in and turn to run first. Push the ice pick into the cylinder hole and lift the lock cylinder out.
Old Sep 24, 2011 | 03:44 PM
78Explorer's Avatar
78Explorer
I get the "dinging" when I remove my ignition key, without turning the switch far enough back toward "acc".
Speaking of clock-springs, steering columns, ignitions, "dinging", etc...
My cruise control doesn't work...the fuses are all good and my horn works and I have no air bag issues (that I know of). I stopped by Ford and had them check for any open recalls on my Bronco...there are none.
What might be the likely culprit? Any "easy" things to check/verify?
Sorry for the hijack...if I need to post my question separately, I sure will.
Old Sep 24, 2011 | 05:05 PM
Edgethis's Avatar
Edgethis
Maybe the button itself went out. does the light come on when you try and activate it? SI the cable in good shape under the hood?
Old Sep 24, 2011 | 06:58 PM
78Explorer's Avatar
78Explorer
Edge...didn't notice any light when I press the button. In the gauges? or on the button itself?
Cable appears good under the hood, but I haven't looked it over REAL well yet.
Old Sep 24, 2011 | 07:35 PM
Edgethis's Avatar
Edgethis
Im not sure then. I have mine disconnected right now so i can't be much help. Maybe a sensor that controls it?
Old Sep 25, 2011 | 06:10 PM
b4hntn's Avatar
b4hntn
With mine the sequence of failure was... Light flashing 3-2, cruise failure , horn failure. The dealer replaced the clockspring to fix it. The cost contributed to my bravery the next time it happened. I learned to disconnect the battery and do something else for a long time for about $300 labor savings.
After the second clockspring and digging into my ding... ding... ding I learned to use a torque wrench on the steering wheel bolt. I almost did not pull it the last time. Farm boy heritage tight was too much.
RSCHAP1
1966 - 1977 Early Broncos
Feb 1, 2016 09:14 AM
ZombieSlayer
Mar 7, 2014 10:08 PM
jtindale
2004 - 2008 F150
Sep 8, 2012 10:01 PM
user 367865976
Jul 3, 2012 08:05 PM
bozzzz94
Aerostar
Jul 19, 2008 02:20 PM
