I need to get a range sensor for my f250. I assume that is what it is called. It is on the side of the trans and it has a large plug that goes into it. Where can I get one??? I have searched online and I even plugged in my vin number to the ford motorcraft site and I cannot find one!
Thats why!! I was searching the wrong thing! Ok so how do I take it off? I took both bolts out and it would not move out any I sprayed some PB on it but am i missing something?
Originally Posted by projectSHO89
Many parts stores' database will call it the "Neutral Safety Switch" or something similar.
Do you have the nut in the center removed? If that nut is off, and both bolts removed, it's just stuck.
there does not appear to be a nut on it. Im not sure how to explain what it looks like but it has like a slot that sticks out that you could get a crescent wrench on but I dont think it comes off??
