Holley Carb ID
Old Sep 23, 2011 | 08:55 PM
jgavac's Avatar
jgavac
Holley Carb ID
So I bought a 1972 Lincoln 460 to put in my 79 F250, and the guy gave me a carb in a bag with it. I didn't use that carb when installing because the one that came with the truck already had all the hookups. I pulled it out of the bag to check and see what it was (I thought it was identical to the one I had), and I came up with this number, but I am not finding anything on the internet about it. So I thought I'd check here
Its obviously a Holley carb, as its stamped right on the metering block. When I looked for the carb number on the air horn, I came up with this
Holley List 80133 1370
Like I said, nothing showed in search results
Any help is appreciated
Jameson
Old Sep 24, 2011 | 06:59 PM
LxMan1's Avatar
LxMan1
It is an OEM Holley 4180 series 600cfm carb. It had a Ford ID tag on it originally that you could use to locate a kit for it, but most are the same. It would have a Ford part# something like D9TE-6210-??
Holley Information Table2 3 - Holdenpaedia
Old Sep 24, 2011 | 07:06 PM
jgavac's Avatar
jgavac
Ok that would make sense. I was just confused because it didn't look like the stocker off my truck, which says "manufactured for Motorcraft by Holley" on the front metering block
black58
Apr 17, 2006 11:25 PM
mrblottokid
Mar 29, 2004 12:04 AM
F250SC
Mar 1, 2004 02:26 AM
F250SC
Feb 24, 2004 02:31 AM
F350SuperCab4x4
Sep 29, 2003 11:31 PM
