Been having a charging problem....
Old Sep 23, 2011 | 01:23 PM
rmodel65's Avatar
rmodel65
Thumbs down Been having a charging problem....
So ive been having a charging problem lately...i found this post in another thread
Originally Posted by gfw1985
Check for voltage at "S" term on regulator. Should be the red/green wire. Without this, it won't charge. This diagram may differ a litlle from what you have, but should help. If you have an idiot light instead of ammeter, the bulb being no good will not allow it to charge. Just a few more things to check.
so my dash lights are out i figure that is probably one of my main problems besides the alternator testing bad(picked up a new one) go to check the bulbs and my instrument cluster basically crumbles in my hands
Old Sep 23, 2011 | 01:36 PM
crazyeddie's Avatar
crazyeddie
Woah...
You don't even need to manhandle the originals to make them break apart like that.
You'll have to buy a new backing plate and transfer the gauges, bulbs, and circuit-board to the new one. Not a big deal at all.
Old Sep 23, 2011 | 02:55 PM
rmodel65's Avatar
rmodel65
the e series vans in the 80s used the same cluster didnt they?
Old Sep 23, 2011 | 03:29 PM
Tim C's Avatar
Tim C
Yes they did. I've got one in my truck. Just make sure you get one with the idiot lights as it is different from a full gauge cluster.
Old Sep 23, 2011 | 08:13 PM
fmc400's Avatar
fmc400
MSEE
Just a side note, GFW's post that you quoted refers to a setup with an ammeter. I guess it's a moot point now, but you have (had) an ALT light. The wiring for this setup is different; in this case you want to check for power at the I terminal of the regulator with the key in RUN, and not the S terminal.
Old Oct 3, 2011 | 08:43 PM
Theframeoff's Avatar
Theframeoff
you still need an instrument panels, I have two
Old Sep 18, 2014 | 07:55 PM
rmodel65's Avatar
rmodel65
necro bump! i finally got a gauge cluster earlier this year. pup it in has a 100mph speedo instead of the factory setup. get it in and nothing still no charging. ends up being a wire going to the voltage regulator(in addition to the cluster problem) on one side of the fusible link. basically fell apart in my hand but looked solid before i touched it.
Viperfoxbat
Jan 26, 2017 05:56 AM
fyredude
Sep 9, 2016 02:16 PM
Jobo57
Jun 2, 2014 02:30 AM
77_150
Jan 30, 2011 08:38 AM
DoofusOfTheDay
1997 - 2003 F150
Dec 22, 2007 01:13 PM
