Sponsored by: Real Truck
DTC Code P0174
Old Sep 23, 2011 | 01:27 AM
Chill E's Avatar
Chill E
DTC Code P0174
This code comes and goes which makes it hard to find the cause. I can tell it's going to turn on the CEL by the way the truck ('05 F350 5.4L) is running. Some days the truck will idle a little rough. When I step on the gas, truck makes a low groaning noise. Other times it runs fine and light will eventually go out. I checked the vacuum lines, exhaust leaks, and replaced the sensor 1 O2 sensor. Anyone got any ideas? Fuel filter?
Old Sep 23, 2011 | 11:30 AM
Furian's Avatar
Furian
You Keep What You Kill
Did you clean the MAF?
OBD-II Trouble Code: P0174 System Too Lean (Bank 2)
Could be MAF, failing fuel pump, PVC...
Part 5 -P0171, P0174 Testing Tips (Ford 4.6L, 5.4L)
Old Sep 23, 2011 | 08:19 PM
Chill E's Avatar
Chill E
I cleaned MAF approx 3 months ago. Maybe it got dirty again, I'll check. I didn't think the VCT 5.4L had a PCV, but I'll check into that again. I checked the vacuum hoses and looked for an exhaust leak, all checked good. Truck ran great today, no problems whatsoever. So now P0174 is pending.
Old Sep 23, 2011 | 11:33 PM
Furian's Avatar
Furian
The PCV is located "inside" the valve cover and cannot be replaced independently of the valve cover.
Old Sep 25, 2011 | 02:06 AM
Chill E's Avatar
Chill E
Okay, well how do check to see if it's bad? Do you have to pull the valve cover and check to see if the ball inside the PCV isn't stuck? Can it be cleaned with brake cleaner, etc... to free it up? Thanks for the info.
Old Sep 25, 2011 | 11:47 AM
Furian's Avatar
Furian
That is a good question... and I don't know the answer. However, your recommended solution sounds as good as any.
gibinez
1997 - 2003 F150
Nov 8, 2015 07:38 PM
carpe_diem
1983 - 2012 Ranger & B-Series
Jan 5, 2015 03:22 PM
donaldm
35
Sep 27, 2012 10:24 AM
gksportster
1997 - 2003 F150
Oct 1, 2006 12:18 AM
blueharley
1997 - 2003 F150
21
Mar 9, 2005 06:54 AM
