Engine upgrade for an altered '53 F100?
Old 09-25-2011, 04:31 PM
Zax53Effie's Avatar
Zax53Effie
Zax53Effie is offline
Hey guys! I am getting a '53 F100 (needs mucho tlc and resto). It came from the factory with a flathead V8, but someone dropped a straight 6 in it. Was looking at some engine options (302, 351 ect), but was wondering how these would pair up to the orig. tranny. This may be a dumb question, so be gentle. Haha! (I know my way around a set of wrenches, but this is my first restoration.) Thanks!
Old 09-25-2011, 05:10 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
To my knowledge they won't hook up without an adapter, which are about $800. Most people just upgrade the transmission at the same time. I have a 302 with a 4 speed toploader in my Mustang and I love it, and a 302 with a 3 speed toploader in my brothers '69 Bronco. Both have good power and are a lot of fun. The 351w will give you a little more power and uses a lot of the same stuff as a 302. (The 351 windsor, not Cleveland or modified aka 351C/351M). For a daily driver the 302 is a great choice, so is the 351w (I'm planning a built up 351w for my Mustang)
Usually any engine changes you're doing you're just going to need to change the transmission as well. You don't have to, but it does require adapters and they generally cost more than anything else. I've seen the old engines with modern transmissions, so it goes both ways, but a adapter was needed.
You can get kits for all the parts to attach it to your truck from places like Mid-fifty.
Old 09-25-2011, 05:21 PM
Zax53Effie's Avatar
Zax53Effie
Awesome! Thanks for the info! Replacing the tranny would be better for me (less wear and the orig. tranny may be locked up anyways), just didn't know how the shifter on the column would match to different trannys. For instance, I found a used 302 (or 351, I can't recall at the moment) with a C4 tranny for a pretty good price. Would this configuration work? Again, I really appreciate the info (and patience Haha)!
Old 09-25-2011, 05:24 PM
Zax53Effie's Avatar
Zax53Effie
It's not gonna be a ground up resto, so much as a "gut and strut" kinda thing. I like a truck with character, just not multiple personalities.
Old 09-25-2011, 05:33 PM
Stephen67's Avatar
Stephen67
I'm no expert when the shifter is on the column, but everything I've come across said it was do-able. I would wait for someone to chime in that knows autos well, they'll be able to tell you everything you'll need to do to make it work.
Be sure to post pictures when you do, we love pictures. They're sorta crack for this forum, lol
Old 09-25-2011, 06:01 PM
Zax53Effie's Avatar
Zax53Effie
Haha. Thanks! Yeah, I only have a side pic as of now. Not a very good angle.
Mr. N
16
08-01-2010 07:35 AM
1990f1504x4man
Engine Swaps
04-25-2005 09:26 AM
Daddywags
02-10-2004 11:41 AM
Frank 373
30
06-01-2003 05:39 PM
Joe fix it
27
02-20-2003 05:23 PM
Quick Reply: Engine upgrade for an altered '53 F100?
